Question about Regal Ware K7001 Coffee Maker
Need the wiring harnes for thermostat on Regal 7001 NF Perculator Urn
The wire for the thermostat is broken and we want to repair it
NF error code during rinse cycle only.
If the unit was working fine before bearing repair, then I lean toward wiring issue. Do a visual inspection of the water valve and all the wires to it. One might have been put in wrong place. If wiring is correct, then maybe a bad water valve. The water valve has multiple solenoids and the one for rinse might be bad. I still think its a wiring issue. Good Luck!
Nov 23, 2015 | Samsung WF337AAL Front Load Washer
2005 Honda NF 100 Wave wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 Honda NF 100 Wave wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
http://www.ethicalbox.co/honda_wave_100_service_manual_download.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
Apr 13, 2014 | 2005 Honda NF 100 Wave
Broken wire harness
you can split the wire case. cut out the split wire/s and put a new wire in. make sure you cut out upto 3 inches either side of the split. best to solder new wire to old wire's . sand down the new solderd parts so there are no sharp edges and tape over them with installation tape. re tape up the harness and job done. if on doors you will need to un clip the harnes at both ends.
Sep 14, 2013 | Cars & Trucks
Plate lights out, everything else works, bulbs replaced
Look in the trunk were the wiring harnes goes along the hinge. Drivers side. Open the wiring harnes and look for broken wires.
Feb 11, 2011 | 1995 Toyota Camry
My left t urn signal and brake light isn't
It's more than likely in the wiring. If it were a relay, the right side wouldn't work either. Sounds like a break in the wiring somewhere...check for voltage with a test light or multimeter. Test once circuit at a time by putting one probe of the test light/multimeter into the hot wire for the brake/tail light. Touch the other probe to a bare piece of metal. If there's voltage, the ground is broken. If you have a multimeter, you can check for continuity between the ground wire and a bare piece of metal. If there's continuity, the ground is good and you need to trace the wires towards the front of the vehicle and find the break. Hope that helps.
Jan 27, 2010 | 2003 Ford Explorer Sport Trac
I own a 1995 E-320 Cabriolet....The strip of lights on the trunk is inop....bulbs are good..I am not getting power to the strip. Is there a seperate fuse for these?
no there is not a seperate fuse. Most likely the wireharness broke in trunk hinge. If you take the right side hinge cover apart you will find a wireharness. carfully open up harnes with razor and repair broken wires. You might even find it broken in half it is a very common problem. make sure you solder in a slightly longer wire and don't solder the wires in the same place so it sill fit back in the trough.
Jan 21, 2009 | 1995 Mercedes-Benz S-Class
Need cord for coffee urn perculator manufactured by consolidated silver co.
This sounds a lot like a standard high-power AC cord and any hardware store should carry these.
Sep 27, 2008 | Coffee Makers & Espresso Machines
Regal Ware K7001 Coffee Maker Logo
63 people viewed this question
Top Regal Ware Coffee Makers & Espresso Machines Experts
Tom Chichester
ray gallant
Are you a Regal Ware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
