Question about Vehicle Parts & Accessories
2000 VW Beetle w/manual transmissiom and diesle engine.The speedometer does not work at all and the gas gauge will only come down when full to 3/4 but gas tank may almost be empty.
The speedometer does not work at all. The gas gauge,when full reads full but may only read 3/4 tank and be almost empty.is there a way to repair these ?
  • 58 Answers
Yes. speed sensor for speedometer and gas level sensor for gas gauge
Posted on Mar 26, 2014
Gas gauge stopped working 1999 vw beetle
1. Sender unit or bad ground wire
2. Just give your self (x gallons in a full tank / y miles per gallon = z at how many miles to fill it to the top again) I did this for years with an 81' rabbit.
Nov 25, 2013 | 1999 Volkswagen Beetle
Just got my 2000 VW New Beetle with 3/4 tank of gas. Drove it 36 miles and its below 1/2 tank. Could it be the gas that they put in? Or something wrong with the car itself?
On just about every vehicle I have ever seen, the fuel gauge will move faster from 1/2 to 1/4 (I never let a tank run past 1/4. Bad for the fuel pump) than from full to 3/4 or 3/4 to 1/2.
Do a mileage check. Fill the tank until the pump stops, reset your trip or note your odometer miles. Dive a few days or a number of miles. Fill the tank again until the pump stops and not the amont it took to fill. Note the number of miles you put on and do the math.
Aug 27, 2011 | 2000 Volkswagen Beetle
2004 Volkswagon Beetle - gas gauge, speedometer, tach not working. Had to jump the car due the battery being low. It's been sitting for the winter. I looked at the fuse box and nothing had to do with the...
It sounds like a relay. There is a relay that ties into all of those systems. Usually a fuse will affect only one thing. I would call your local VW dealer and ask them if that sounds like a relay. If so, it should be mounted under the console beneath the dash. Good luck. Hope this may help.
Dec 28, 2010 | 2004 Volkswagen Beetle
In a 2000 VW Beetle where is the spare and is it a full sized
Lift up the floor in the very back.Nope it's not full sized.
Mar 01, 2010 | 2000 Volkswagen Beetle
Tack,gas gauge,speedometer not working fuse?
It takes a new instrument cluster. About 800 dollars at vw. They also have to program the computer to accept the new cluster.
Oct 19, 2009 | 2001 Volkswagen Beetle
Speedo,tacho,fuel guage not working on my 2000 vw beetle any ideas,checked all fuses,could it be a relay?
Not likely that a relay would cause this.
Modern instrument clusters are packed full of capacitors and numerous other types of electrical components. A faulty soldered connection can create havoc with the entire cluster.
There are numerous cluster repair facilities across the country. Google "speedometer repairs." Scan down the sites and see if problems with your model car are mentioned.
Oct 16, 2009 | 2000 Volkswagen Beetle
AUTOMATIC 2000 VW BEETLE - SPEEDO NOT WORKING!!!!
NOT REALLY FOR SURE BUT I THINK IT HAS A SPEED SENSOR EITHER ON THE WHEEL OR LOCATED ON THE TRANSMISSION I WOULD CHECK THOSE AREAS.
Jun 15, 2009 | 2000 Volkswagen Beetle
Fuse box diagram for a 2000 vw beetle
There should be a diagram in your Owner's Manual. I have one for my daughter's 1998 Beetle that should be the same as in the 2000 Beetle. Can email it to you if you post an email address that I can send it to.
Jun 11, 2009 | 2000 Volkswagen Beetle
Emergency latch for gas cap 2000 VW Beetle, where is it?
From the manual:
  • Open the rear lid.
  • Open the cover on the backside of the luggage compartment. To open the cover, turn the two "quick-releases" and fold the cover down.
  • Reach through the opening by the fuel filler flap. Grab the cable with th plastic covering and pull down. The filler flap will open by itself.
Best of luck!
Apr 10, 2009 | 2000 Volkswagen Beetle
Vehicle Parts & Accessories Logo
79 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
