Question about Keurig Special Edition B60 Coffee Maker
Keurig b60 is pumping the water back into the tank instead of the cup as well it is leaking out the bottom of the machine, i have tried cleaning the needles however, not sure what's causing it to do t
Don't know why it started leaking and pumping back into the resouvoir tank?
    Problem Solver:
  • 14 Answers
Check the water output in the brew head itself. Open the head like you were going to out in a k-cup, and run a small object like a paper clip UP the water output to make sure it's clean. Then remove the K-cup holder and clean the water output line at the bottom the same way.
Posted on Apr 20, 2014
3 Suggested Answers
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
Keurig B60 not brewing a full cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
My keurig keeps spitting the water back into the water reservoir and not brewing a full cup. I have cleaned the needles and have not descaled. How do I fix it??
Hi, Place your finger over the tube going back to the tank and force the water through the needle...
heatman101
Sep 11, 2011 | Keurig B60 Coffee Maker
I have a Keurig Breville machine & it seems that it is not pumping the water. What can I do? Anna
heatman101
Aug 06, 2011 | Keurig Special Edition B60 Coffee Maker
My machine will not pour the water through the cup. Instead it pumps the water back into the water container from the top.
heatman101
Jul 09, 2011 | Keurig B60 Coffee Maker
Keurig B60. Brand New used maybe 4 Kcups. Now it won't fill a full cup setting. Maybe 1/4 cup. You reset, get a little more to run through. At this rate going to be a long time for a full cup. took...
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
Dec 18, 2010 | Keurig B60 Coffee Maker
The Keurig is heating up the water, yet is does
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
May 13, 2010 | Keurig B60 Coffee Maker
My Keurig B60 is suddenly not dispensing water when a K-cup is in the machine. Dispenses fine with no cup in chamber.
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Dec 03, 2008 | Keurig B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
137 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
