Question about GE (ZDWR240PBS) Wine Cooler
How can I verify my thermostat is good?
Bought this wine cooler secondhand. It doesn't cool. I have verified the compressor windings are good, the starting relay and 4tm thermal overload is also good. I didn't check the capacitor because I am not ready to unsolder it. My next thought was the thermostat, but it's a digital thermostat and I can't just "jumper" across it. Any ideas or anything else I should have checked?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
U can just take the digital board out of it all together and wire the compressor up so it starts up by its self. if it is a problem with the cap when u try and start it the compressor will be getting voltage are u getting voltage? do u know what type of thermostat it is? is it giving u a reading of what the temp inside is?
Posted on May 22, 2014
the dr
  • 447 Answers
SOURCE: low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Posted on Oct 11, 2007
  • 58 Answers
SOURCE: relay and overload on the compressor
the relay will be burnt up inside, shake it and little pieces will come out if its burnt out. the overload usually is never the problem
Posted on Mar 12, 2008
Just_Bobz
  • 448 Answers
SOURCE: Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
Posted on Jan 17, 2009
  • 10 Answers
SOURCE: Compressor won't turn on. Lights turn on. Won't cool anymore.
Make sure that the defrost timer is not stuck in defrost mode also the compress may be stuck. you can purchase a compressor booster kit from your local appliance parts store for about $15.00.
Posted on Mar 07, 2009
  • 19 Answers
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
Posted on May 09, 2009
BC112G Wine Celler Not Cooling
Open the terminal box ontop of the compressor. Check if there is a thermistor inside. If there is, check the continuity. If the continuity is alright, check the winding resistance of the compressor. If the winding resistance is good, then the fault is in the controls.
Mar 31, 2017 | Haier BC112G Wine Cooler
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
Wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Mar 01, 2010 | KitchenAid KUWS246E Stainless Steel Wine...
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
GE (ZDWR240PBS) Wine Cooler Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
