1989 dodge caravan heater will not work
Wondering if the heater coil; or a wire or just need a fuse to get heater to work
  • 141 Answers
SOURCE: 2000 dodge grand caravan rear heater core tubes need replacing
a lot of pain and heart ache. even on a rack they are a pain . check with your dealer there wae a recall on them for failing its worth the phone call to see kdc744
Posted on Feb 08, 2009
  • 1596 Answers
SOURCE: need wireing diagram for 2002 dodge grand caravan
------>>>FRONT>>>>of Van >>>>
______________________________
#5 cyl #6 cyl
#3 cyl #4 cyl
#1 cyl #2 cyl
_________________
I COIL BLOCK I
I I
I #3 #1 #5 I
I I
I I Firing Order Is
I I 1 2 3 4 5 6
I #6 #4 #2 I
I _______________I_
the Wires Go Accordingly to prospective Terminals, So Sorry Unable to Send Pics through FixYa, A Formating Problem Exists
and they show on my end but not on your end this is TRUE and CORRECT To The BOOK other than the Lines from Coil to Spark Plug ENDS at CYLINDERS. Please dont Forget to RATE Me
Thank You And Happy Motoring!!
Posted on Mar 27, 2009
LEFTY64
  • 69 Answers
SOURCE: Need to replace the heater core in a 1995 Dodge Grand Caravan SE
1991-95 Models
  1. Disable the air bag system by disconnecting the negative battery cable.
  2. Have the system discharged by a qualified professional mechanic using an approved recovery/recycling machine.
  3. Drain the cooling system.
  4. Remove the steering column cover and left and right side under panel silencers.
  5. Remove the center bezel by unclipping it from the instrument panel.
  6. Remove the accessory switch carrier and the heater/air conditioning control head.
  7. Remove storage bin and lower right instrument panel.
  8. Disconnect the blower motor lead under the right side of the instrument panel.
  9. Remove the right side 40-way connector wiring bracket.
  10. Remove the lower right reinforcement, body computer bracket and mid-to-lower reinforcement as an assembly.
  11. Disconnect the vacuum lines at the brake booster and water valve.
  12. Clamp off the heater hoses near the heater core and remove the hoses from the core tubes. Plug the hose ends and the core tubes to prevent spillage of coolant.
  13. If equipped with air conditioning, remove the H-valve and condensation tube.
  14. Disconnect the temperature control cable and vacuum harness at the connection at the top of the unit.
  15. Remove the retaining nuts from the package mounting studs at the firewall. Disconnect the hanger strap from the package and rotate it aside.
To install:
  1. Remove the temperature control door from the unit and clean the unit out with solvent. Lubricate the lower pivot rod and its well and install. Wrap the heater core and/or evaporator with foam tape and place in position. Secure with the screws.
  2. Assemble the unit, making sure all vacuum tubes are properly routed.
  3. Install the assembly to the vehicle and connect the vacuum harness. Install the nuts to the firewall and install the condensation tube. Fold the carpeting back into position.
  4. Connect the hanger strap from the package and rotate it aside. Install the 2 brackets supporting the lower edge of the heater housing. Connect the blower motor wiring, resistor wiring and the temperature control cable.
  5. Install the retaining screws from the right side to the steering column. Install the instrument panel trim covering and reinforcement.
  6. Assemble the unit, making sure all vacuum tubes are properly routed.
  7. Install the assembly to the vehicle and connect the vacuum harness. Install the nuts to the firewall and install the condensation tube. Fold the carpeting back into position.
  8. Connect the hanger strap from the package and rotate it aside. Connect the blower motor wiring and temperature control cable.
  9. Install the lower right reinforcement, body computer bracket and mid-to-lower reinforcement as an assembly.
  10. Install the right side 40-way connector wiring bracket.
  11. Install the lower right instrument panel and storage bin.
  12. Install the heater/air conditioning control head and accessory switch carrier.
  13. Install the center bezel to the instrument panel.
  14. Install the under panel silencers and steering column cover.
  15. Install the vacuum lines at the brake booster and water valve.
  16. Connect the heater hoses to the core tubes.
  17. Using new gaskets, install the H-valve and connect the refrigerant lines. Install the condensation tube.
  18. Have the system evacuated and recharged by a qualified professional mechanic, utilizing the proper equipment. Add 2 fl. oz. (59 ml) of refrigerant oil during the recharge. Fill the cooling system.
  19. Perform the Air Bag System Check procedures outlined in this section before connecting the negative battery cable.
  20. Connect the negative battery cable and check the entire climate control system for proper operation and leaks.
Posted on Apr 08, 2009
SOURCE: NEEED FUSE FUSE BOX LAYOUT FOR 2003 DODGE GRAND CARAVAN
You can get free owners manuals online at:
http://www.edmunds.com/ownership/howto/articles/120189/article.html
or just type "owners manuals" in your search.
Here is a post I found that worked for my 2005 caravan.
For a 2001 Dodge Caravan: The owner's manual is vague, only stating that all fuses are under the hood in the fuse box, no diagrams. Once you have removed the fusebox cover, the diagrams for what each fuse does is provided under the lid. UNCLEARLY marked is the radio fuse, a 20amp fuse located 2nd row from top to the right of the accessory relay. It is marked: RDO/IP IGN.
Jake
Posted on Sep 19, 2009
  • 3 Answers
SOURCE: 2002 Dodge Caravan horn doesn't work. Fuses are good.
2002 dodge grand caravan horn problems
Posted on Mar 02, 2011
My 2004 Dodge Caravan Tachometer stopped working
have you checked the fuses? it more than likely blew a fuse if not then maybe fried wiring from jump start.
Feb 24, 2013 | 2004 Dodge Caravan
My 2005 Dodge Caravan front heater blower does not work. What are you suggestions?
check the fuse first with a test light, then, check the voltage to the 2 wires for the blower motor also with ignition on without running the engine. let me know how that turns out for the rest of the instructions
Dec 29, 2010 | 2000 Dodge Caravan
Cant find heater core 1989 dodge caravan , need to see if it is not working. any advice?
Your heater core is in your dash, and yes, its a pain to get to. My dad and I did my grandma's in the same minivan, and we ended up taking out the front seat just to give us extra work room. Usually if your heater core is bad, you will have a big wetspot in the passenger side floor board. The only thing that really can go wrong with a heater core is it leaks, thus the wet spot.
Apr 24, 2010 | 1989 Dodge Caravan Cargo
I think the coil went on my 2000 dodge caravan. How do I test for that?
disconnect one of the plug wires from coil,install a inline tester and check for fire. if that test is ok then use the same tester to check the coil wires to the plugs. check inthe fuse panel to see if you have a blown fuse or relay first. if the coil is bad then before u try to remove it disconnect the battery.
Mar 28, 2010 | 2000 Dodge Caravan
My heater fan for my 1990 dodge caravan 3.3 litre up front only works when it feels like it,the rear heater fan works well.wondering if its a short in the wiring.did replace the manuel switch that turns it...
Hello purplerobe.
First thing to do if you haven't already is check the fuse in the panel. It's fuse #4 and a 30 amp.
If that's ok you need to go to the blower motor under the dash and check for power on the dark green wire. It may take a little searching, I think these ones are well hidden inside. You will need the key on and blower set on high to do that. A 12 volt test light would be really handy here. If you have power then verify the ground side is grounded. So therefore if you then have power and ground to the motor you then need to replace it.Not an easy task on these model years.
Sure hope it's just a fuse for you.
Nov 27, 2009 | 1990 Dodge Caravan
No power on wire to coil check w/tester
when you put the ignition key on does the check engine light is on or stay on if it is not on you got no power to computer on the computer check for coroded pink or blackand green wire please let me no thank pierre
Jan 26, 2009 | 1990 Dodge Grand Caravan
Where is the heater and turn signal relay located 1992 caravan
These are seperate fuses and seperate turn signal falsher which evenually go into the same wiring. See my answer to your previous question. Good luck and hope it helps.
Jan 19, 2009 | 1992 Dodge Caravan
Windshield wipers not working
if there is 12V at the motor, the motor has gone bad. replace accordingly.
to test, disconnect and put 12V directly to the motor contacts.
Dec 24, 2008 | 1989 Dodge Caravan Cargo
Lost ignition...turns over but no spark
make sure that the distributor module is ok first.Check that the ign coil is getting a pulse signal when engine is turning,and check ecm fuse and that engine is grounded to frame.
Nov 25, 2008 | 1989 Dodge Dakota 2WD
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
