Think there is a wire loose on heater coil
On a 1989 dodge caravan heater is not turning on and wonder if its just a fuse or a wire
cranegang
  • 21 Answers
SOURCE: where is the heater and turn signal relay located 1992 caravan
These are seperate fuses and seperate turn signal falsher which evenually go into the same wiring. See my answer to your previous question. Good luck and hope it helps.
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: 1989 Dodge Ram D50, no spark. coil may be miswired.
Check the resistance on the coil. the (+) (-) side should be about 10 Ohms resistance and the part that goes out of the coil should be 1-2 ohms resistance. Get yourself an ohmmeter and check it. best way to check is to figure out what wire runs from the computer to the coil and follow the wiring all the way to the coil making sure theres no rips or shorts. If there isnt, then I would splice into the two wires and run two new wires over to the coil. If it still doesnt have spark then its a faulty computer and should be replaced. Good luck
Posted on May 03, 2009
techbuster
  • 5081 Answers
SOURCE: Heater blower motor replacement -1997 Dodge Grand Caravan
Remove the cover plate on the passenger side of the heater box, 3-4 screws.
Unplug the motor assembly, remove 3-4 more screws that hold the motor in place and pull it down from its position. Get an aftermarket motor and installed it in the original housing with the original squirrel cage.
Installation is the reverse of removal.
Posted on Nov 23, 2009
mrgreenz
  • 962 Answers
SOURCE: heater motor not working, checked fuses none,ford van
Probably the resistor plug located under the dash.
Posted on Dec 29, 2009
andy233
  • 15 Answers
SOURCE: my dodge 2000 caraVAN HEATER DOESN'T WORK
try the coolant flush on the heater core feel hoses if not both out see if you have a control valve near the firewall engine compartment if so see if moving cable will change the hose temperature . then next step is what is the engine temp does it have water in it usually a low level first stops the heater refill cold and pressure test cold and hot if no tools let it run 1 hr and watch for leaks if it was low make repairs see if that works
Posted on Jan 03, 2010
My dodge caravan has a miss. Can u help?
Hi Ray, concerning your miss while turning, the advice I have is to check your wiring into your coil. Sometimes dirt or a loose wire will do that. Always have your car in park and disconnect the negative cable on your battery. hope this works for you!
Jan 07, 2016 | 1999 Dodge Caravan
Electrical wiring to my 1998 dodge caravan distributor
There's a lot of vibration in the distributor, so it's an area where you may find loose wires.
Look for loose wiring in the distributor or coil.
Hope this helps.
Mar 26, 2015 | 1998 Dodge Caravan
My 2005 Dodge Caravan front heater blower does not work. What are you suggestions?
check the fuse first with a test light, then, check the voltage to the 2 wires for the blower motor also with ignition on without running the engine. let me know how that turns out for the rest of the instructions
Dec 29, 2010 | 2000 Dodge Caravan
I think the coil went on my 2000 dodge caravan. How do I test for that?
disconnect one of the plug wires from coil,install a inline tester and check for fire. if that test is ok then use the same tester to check the coil wires to the plugs. check inthe fuse panel to see if you have a blown fuse or relay first. if the coil is bad then before u try to remove it disconnect the battery.
Mar 28, 2010 | 2000 Dodge Caravan
Car heat takes 10 to 15 minutes on a 2005 dodge
could be clogged up heater core or the heating helper element ..if you look for the heater air box you should see a 3 wire plug with i believe its 2 screws on it remove it and start the car and have someone hold it {not the coil wire ends and turn on the heat it should glow red hot this is the heater coil helper you may also have insufficient antifreeze remove radiator cap and check fluid levels also while your there feel the top and bottom hose to see if they both get hot and that you feel water in them but 1st ensure the radiator is full if just the top hose going into the heater-core to the firewall is hot and the bottom one is cold you should have a radiator flush to dislodge the Gunk buildup in the heater core .
Dec 07, 2009 | 2005 Dodge Grand Caravan
My heater fan for my 1990 dodge caravan 3.3 litre up front only works when it feels like it,the rear heater fan works well.wondering if its a short in the wiring.did replace the manuel switch that turns it...
Hello purplerobe.
First thing to do if you haven't already is check the fuse in the panel. It's fuse #4 and a 30 amp.
If that's ok you need to go to the blower motor under the dash and check for power on the dark green wire. It may take a little searching, I think these ones are well hidden inside. You will need the key on and blower set on high to do that. A 12 volt test light would be really handy here. If you have power then verify the ground side is grounded. So therefore if you then have power and ground to the motor you then need to replace it.Not an easy task on these model years.
Sure hope it's just a fuse for you.
Nov 27, 2009 | 1990 Dodge Caravan
No power on wire to coil check w/tester
when you put the ignition key on does the check engine light is on or stay on if it is not on you got no power to computer on the computer check for coroded pink or blackand green wire please let me no thank pierre
Jan 26, 2009 | 1990 Dodge Grand Caravan
Where is the heater and turn signal relay located 1992 caravan
Jan 19, 2009 | 1992 Dodge Caravan
Lost ignition...turns over but no spark
make sure that the distributor module is ok first.Check that the ign coil is getting a pulse signal when engine is turning,and check ecm fuse and that engine is grounded to frame.
Nov 25, 2008 | 1989 Dodge Dakota 2WD
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
