Question about MXR M288 Bass Octave Deluxe
Growl knob not working mxr 288
When I start moving the knowb clock-wise the volume of the octaver doesn't turn up. Sometimes when I reach the end of the turn it starts to sound but at a very loud volume.
    Sergeant:
  • 336 Answers
I would get a can of good electrical contact cleaner and open the unit, spray the cleaner into the back of the controls while rotating them back and forth quickly. This will somewhat clean the control contacts inside eliminating most dust and corrosion. If the control is too old and dirty, it may not work but, I would definitely try. It probably has a special made potentiometer that would be hard to find and replace. They usually have special legs attaching them to the board. I am almost positive that the control is bad or dirty, though. If the sound gets loud when almost all the way up, it does indeed work, just not in a dirty position. That already proves it.
Posted on Mar 29, 2014
The volume conrtol knob on my Casio Privia Px-320 doesn't work. The volume won't go up or down and the knob feels loose. Can I fix it at home?
I found an answer at the end of this page: http://music-electronics-forum.com/t31080/ After replacing the potentiometer volume is OK. The original potentiometer has a very delicate axis.
Dec 29, 2012 | Music
Volume of some keys (one octave) are lower than rest of the keyboard, any advise please ?
Take it in for repair. There may be a broken line for the velocity sensing of that octave of keys that is causing the velocity to be sensed low. The repair is NOT DIY if this is the case.
Sep 02, 2011 | Roland Juno-D
Recently purchased brand new m116 fullbore metal and it doesn't seem to be receiving power....
The plug into the inout jack turns the unit on. You don't mention if you are using a bettery or an adapter...
Aug 15, 2011 | MXR M116 FullBore Metal Pedal Guitar
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
Jan 12, 2011 | MXR Stereo Chorus Pedal Guitar
I cant get my knobs or sliders on my oxygen 49 controller working keys, octave and mode and pitch work fine, its just the sliders and knobs
Here is a link that might help:http://www.m-audio.com/index.php?do=products.directlink If your DAW isn't supported it might have a learn function that might help. Make sure you download the latest update.
Oct 18, 2010 | M-Audio Oxygen 49 USB Midi Controller
Bypass is fine, LED lights when active, but signal is very low in volume when effect is active. Almost inaudible.
Make sure power voltage is adequate. If using a battery, the LED will light LONG after the batteery is beyond usability.
Jan 17, 2010 | MXR Phase 90 Pedal
MXR Phase 90 doesn't phase only clean signal. The oscillator is working and I have changed the BJT's.
sounds like a switch contact problem, try some surgical alcohol. (for the MXR not for you!!!)
Dec 31, 2009 | MXR Phase 90 Pedal
Mxr phase 90 block logo and the 9v power jack not working
These break and SOMETIMES the circuit board gets cracked.
Open up and inspect for damage. If board is cracked, bridge broken traces by soldering wires around the break.
If the solder is broken, resolder it.
If the connector is damaged or weak spring, replace the connector.
Sep 12, 2009 | MXR Phase 90 Pedal
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
MXR M288 Bass Octave Deluxe Logo
Top MXR Music Experts
Vito Vacirca Jr.
Are you a MXR Music Expert? Answer questions, earn points and help others
