Question about GE Microwave Ovens
I have the replacement door handle for JVM1440BD. How do I get the door off?
I have part # WB15X10022 now how do I get to the screws on the old handle to replace it with this handle. GE Spacemaker1440BD
  • 61 Answers
Bit tricky as you have to dismantle the door first then remove black back pannel to acces screw to the handle.best of luck be carefull not to pry open the pannel by using too much force
Posted on May 18, 2014
MicrowaveSvc
  • 9085 Answers
SOURCE: Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 06, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Spacemaker Microwave Handle Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 10, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Posted on Apr 01, 2009
How to replace WB15X10022
That would be the door handle used on several GE and Kenmore models.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jun 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing a broken handle on GE microwave model JVM1660SB 005. I can't get at all the screws on the old handle.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: If you need a diagram, pcappplaincerepair.com has some excellent exploded view illustrations you can refer to for assistance. If you haven't purchased a new door handle yet, the part number is WB15X10022.
Oct 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to install WB15X10022 GE Microwave Handle.
This is a generic answer
Open the door and look carefully for a plactic strip that may be covering screws. If none. look on the bottom edge or the edge with the hinge. Remember, someone had to assemble the door so there has to be some way to disassemble it. I have never seen one that can not be opened (glued, cemented or welded closed) Remember, most doors are spring loaded and may snap shut on you with the door partially removed. Also, keep in mind the process you went through to get it apart. You will have to reverse that process. You may want to take pics with your cell phone as you progress.
Once open (and you may need a 'Torx' tool to remove the screws), replacing the handle should be simple.
Let me know how you make out.
a
Sep 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace GE Spacesaver microwave door handle
never attempt to repair or replace the handle or any part of the door as this almost allways will lead to microwave leakage this will cause most certain death..
replace door or replace the unit today the uniy a very inexspensive..
nbcrca:)
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven Door Handle Replacement
You shoul take off the hole door, use something like a flat screw driver and wedge the plate off.
some of the mics got tamper holes where it hooks in.
Hope it works...
Sep 09, 2008 | Whirlpool MH7155XM Microwave Oven
Kenmore 363.62709200
I searched by that model and there was no match. Then I found model 363.62709300.
If that looks like yours, then color may be the only difference.
They show the handle as (GE) part # WB15X10022 for $29.99.
You can get it a little cheaper here: http://tinyurl.com/gv383
Feb 27, 2008 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
