Question about Refrigerators
My fridge is running and it wont cool there is no ice in the back of the freezer
It is a side by side and neither one is working. it is a whirlpool modle ED22TQXFNDO series SH1141577. it is running and clicks every now and then and there is a little cool air coming out of it.
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Check the compressor start device.
Posted on Apr 13, 2014
  • 1462 Answers
SOURCE: freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Posted on Apr 09, 2007
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
  • 115 Answers
SOURCE: freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Posted on Dec 30, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
SOURCE: whirlpool gs6shexns00 fridge
I had a very similar problem- flickering light bulbs, shorting-out noises, electronic temperature displays not working. I had to replace a small circuit board (the "Electronic Control Board") accessed from the rear of the fridge. A relatively easy do-it-yourself job.
Refer to this link at PartSelect.com:
http://www.partselect.com/PartDetail.aspx?Inventory=2180152&SourceCode=1
Posted on Feb 23, 2010
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer of my whirlpool fridge/freezer does not work - but the fridge is ok. Sometime back I tried connecting it to a solar power system. Could this be the reason. If so what component could have...
No,
Check and make sure the unit is not froze up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ref side not getting cold, freezer still cold
Hi, Is the Freezer still cold? If so either the Fan (In back of freezer-Remove rear panel) is not working or the vent between freezer and fridge is close (side panel between freezer and fridge) Check either of those should be able to pick which is not working
Jul 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
