Question about Garden
Need diagram how to reinstall carburator on poulan 295 pro chainsaw
Poulan 295 Pro..I removed the carburator and now I need symatic showing how to reinstall it
    Guru:
  • 145 Answers
Partstree.com or jacksmallengines.com I dont know if there ever was a service manual. I havent seen one
Posted on Apr 13, 2014
dontbother10
  • 2220 Answers
SOURCE: Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Posted on Oct 28, 2009
dontbother10
  • 2220 Answers
SOURCE: What is the correct gas/oil mix
50:1 according to this:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c2b3efd6af050e6b88256f77001bfbdd?OpenDocument
I suspect the manual says 40:1, but if properly adjusted it will operate better on 50:1.
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil = 50:1.
I gallon of premium fuel to 3.2 ounces of quality 2-cycle oil = 40:1.
HTH David;
Lou
Posted on Feb 10, 2010
jrox55
  • 66 Answers
SOURCE: poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Posted on Feb 27, 2010
  • 6 Answers
SOURCE: Poulan Pro 295 won't keep running.
pull the black dust cap on top there are three screws going down, the idle screw is on the left side (if you were holding the saw) near the top of the carb it has a spring around it. the 2 weird screws under that are the mixture screws hi and low rpm you really shouldn't mess with those unless your sure of what your doing. if that doesn't work there is a really small hole ( and I mean small) in the bottom of the carb for a diaphragm if that gets clogged it runs bad, also vibration can loosen the cylinder bolt turn the saw upside down and there are (or should be 4 bolts) make sure they are tight if one already rattled out take the one kitty corner to Lowe's or a hardware store and get a replacement.
Posted on Mar 06, 2010
  • 4088 Answers
SOURCE: Poulan Pro 295 46cc chainsaw that won't start
Does the spark plug get wet with fuel when pulled through? If dry, try spraying a little starting fluid in the plug hole and reinstall the plug. If it pops at least once, you have fuel delivery problems--look for hardened/ cracked fuel lines. Clean the muffler arrestor screen. When the muffler is off, check the condition of the piston skirt and cylinder wall for deep scoring or obvious wear. Make sure the primer button (if equipped) is filling with fuel when pumped a few times. If it doesn't, make sure the bulb is not hard or cracked and check the lines going to and from it. Check the carburetor bolts and nuts for tightness. The fuel filter in the tank could be plugged, fish it out and check. If you have checked all these items, it may be time to clean and rekit the carburetor. Hope this helps!
Posted on Mar 08, 2010
My poulan pro chainsaw series 295 gets a spark and furl to the cylinder but wont fire or turn over when cranked
Before you do too much i would remove the muffler and check the condition of the piston through the exhaust port, any sign of scuffing or piston damage and it will need to come apart to assess the damage.
Feb 17, 2011 | Poulan Garden
Removal and installation of chain sprocket for poulan pro 295 chain saw.
Download and open the link below:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
See page 16.
This may also be helpful (bottom), it is possible to mount a chain backward.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Won't start
I have a poulan pro 295. Can't get it to fire. I've replaced the plug, and ignition coil. cleaned the entire chainsaw.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Lou
Oct 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Gots spark but won't start
If the engine is getting spark and you have tried starting fluid sprayed into carburator then it is not the switch as all the switch does is ground out the primary to kill the spark. It is now either the compression(lack their of) or the timing (Sheared flywheel key, for example)
Feb 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
