Question about Dacor 30-in Downdraft Range Hood Stainless Steel ERV30
The vent ws turned on and uncontrollably went up and down till I unhooked the switch (took away the power). what part do you think i may need to replace? thanks J
I would like to know which parts to order to replace?
Duramax diesel w/allison trans; went into limp mode while towing 8000lbs; cooled down ran fine till it heated up again then limp mode; unhooked and drove 200 miles, ran fine; afraid to tow again help
Does the transmission have an over heat switch? That is the only thing I can think of. If so, you need to add another transmission cooler to assist the one you have for those heavy loads.
Aug 29, 2017 | Cars & Trucks
My Mitsubishi ws 65819 won't turn on. When I unplug the tv and plug it back in the small light under the word timer flashs but that's it
its in high voltage shutdown. if ya wanna cheat? it'll take a dimmer type switch to cut the voltage in half. slowly till u can turn it on. then full voltage. if it is in high voltage shutdown you then need a technicians eye 2 see the symptom thats causing the problem. remember the shutdown is caused thru a saftey mechnism, and don't burn the house down. my 1000 mile away diagnosis says your voltage regulator or horizontal is out. most problems are power supply related, thus the voltage reg. is bad. if you use a higher current dimmer switch ...its a cheater tool that technicians can use, so be carful. keep an eye on all cords...heat should not be present in any appliance , etc. thats the wire to the wall.
Nov 22, 2010 | Mitsubishi WS-65819 TV
Turn off and on codes
samsung usually doesnt have a code. hide a switched power strip or something behind the tv or unhook it somehow when you're away. you can lock cableboxes and sat boxes sometimes, but i think that panasonic code is a rare thing
Jun 17, 2010 | Samsung UN55B8000 55 in. LCD HDTV
I took my Camry 2000 (V6) to Sears for brake and power steering fluid flush. My brake light went on after the maintenance. Took it back the next day. They said my hand brake was not totally down. I did not...
if sears adjusted the brakes then the emergency brake handle can come on sometimes this has to be adjusted also ( always be careful when haveing anything power flushed as this can easely pop a seal and start leaking a few weeks down the line
Mar 03, 2010 | 1997 Toyota Camry
Auto battery keep going down on my 1991 Plymouth Laser
Unhook the power terminal possitive + hook a 12 volt light to it and the battery close all doors and turn off all switches begin removing fuses from the fuse pannel till the light goes out this is your drain.
Aug 27, 2009 | 1991 Plymouth Laser
MITSUBISH WS 65807 GREEN LIGHT TURNS OFF PROBLEM
you could try checking your convergence board, i have a samsung that when powered on the red timer light flashed a few times and then went out , turns out it was my converge board, when i unhooked it the worked again colours were out of align ,but fixed board and all is well
mikeyfix
May 07, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-A65 Sparks coming from the Bulb Ballast
Your crt is leaking coolant onto the board , you need to rebuild whichever crt's are leaking and fix the board!
Nov 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Dryer runs for 20-30 seconds then turns off
Mine just did the same thing, so i took it all apart and spun the motor with my hands for a few minutes. And it began to work. I think it is just because the motor is seized let me know how you make out.
http://www.diynetwork.com/diy/ha_maint_repair/article/0,,DIY_13869_2268643,00.html
That is all I can help you with for now!
Mar 19, 2008 | Maytag HYE3657A Electric Dryer
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Dacor 30-in Downdraft Range Hood Stainless Steel ERV30 Logo
69 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
