Question about Stack-On E48MBE 48-Gun Fire Safe With Electronic Lock
Electronic lock pad does not work
New battery does not work either
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    My key pad does not respond at all, no beeps and does not lock or unlock door. Thought it was the batteries but I changed them and it still does not work. When I put the new batteries in it did flash...
    There is only a one year warranty on the electronics and the maker (Stanley-Black and Decker) will not sell the electronic parts separately. Check the installation manual for a reset procedure - basically the lock might be "forgetting" it's programming. Another possibility is that it's trying to move the bolt and can't. Be sure the bolt moves freely.
    If the electronics have failed and it's out of warranty, there are other brands that are key-compatible with Kwikset. Weiser locks can also be keyed to be compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
    Jul 05, 2011 | Weiser Lock Powerbolt 1000 Lock
    I just installed last week with new included battery and twice since The push pad was non responsive. I play with it for a minute or so and then the number pad lights and sound comes back and door...
    Assuming you've followed the installation directions accurately and do not have a mechanical bind within the lock or between the lock and strike plate (how does it operate when cycled with the door open?). Beyond that, I'd exchange the lock with a new one.
    On this page you will find videos of how to install and how to program your lock:
    http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
    If all else fails, here is a link to the customer service contact page:
    http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
    Apr 18, 2011 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
    Touch pad does not work on weiser lock powerbolt. Batteries are new and beep when installed. Checked power board and is installed properly.
    I found this Frequently Asked Questions sheet for the Powerbolt 1000:
    http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
    I hope this helps.
    Feb 23, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
    Cant open my programmable key pad safe. the code wont work
    Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Aug 12, 2010 | Sentry Fireproof Safe
    I programed the lock. It beeped in recognition of the code, but the lock doesn't turn. The batteries are okay. How do I get the door to lock/unlock using the keyless pad?
    if the batteries are new and good, sounds like a problem with the lock motor..is it a new unit? if so exchange it. try another set of batteries.
    Feb 06, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
    Replaced batteries and the key pad will not work...what else could be the problem?
    Did the lock come with a default or master pass code? It's possible that the memory was cleared when the batteries went dead. On some of these devices, you have to change the batteries one at a time to keep the codes.
    Apr 06, 2009 | Deadbolt Locks & Locksmithing
    How do I change an electronic safe combination?
    hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
    Feb 18, 2009 | Schylling Combination Steel Safe
    Stack-On E48MBE 48-Gun Fire Safe With Electronic Lock Logo
    51 people viewed this question
    Top Stack-On Electronics - Others Experts
    Are you a Stack-On Electronics - Other Expert? Answer questions, earn points and help others
