Question about JVL Echo Encore 2 Entertainment Center
Need to change the power supply how do i open the front ?
It no longer powers up
Element elefw408 not powering up do you think its the main board
TV Parts Universal TV Stands DLP Chips ShopJimmy If there are DC voltages no longer present on the power supply board, these guys can either repair your board or supply you with a new one.
May 05, 2017 | Element Televison & Video
Does not turn on
Are there any lights? If not then I would suspect your power supply. If there are lights it is most likelly your power supply but it can also be just about everyother part on that TV. signal board, T-con, power supply. If you need a power supply.
You can get parts at www.interliquidparts.com
Dec 02, 2011 | LG 42LH30 42 in. LCD TV
My VEA 42 inch TV is no longer getting power. Is it just a fuse or do I need to replace something els.
If there's no led light at the front panel of your unit, this is an indication that the power supply board is not working.
Please check the instructions below.
If you're unit is not under warranty period(if so, avail it because the manufacturer will fix it for free) you may open the back cover of it.
1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 30, 2011 | Televison & Video
Compaq evo 510 tower 1256 ram win 7 nvidia 6600 garapics card in AGP slot upon pressing power button goes green for about 1 sec and then nothing starts, power led just remains steady flashing red, some...
Could be the power supply. Try unplugging the internal hardisk power, the internal cd power and anything else that is connected internally apart from the motherboard power supply. This may reduce the load enough to allow the motherboard to be powered.
As power supplies age, internal electrolytic capacitors dry out and can no longer store sufficient charge to provide power. This usually affects the higher voltage rails more, so USB devices can still get power from the 5V rail.
Try a working power supply from another computer if you can or buy a replacement to fit your case.
Feb 22, 2011 | Compaq Evo D510 Minitower (Open Box)...
The power button clicks continuously and no longer works to turn the tv on
You can open the TV and inspect the power supply for bulging or leaky capacitors near CN801.
The power supply is failing due to defective capacitors.
If you need the power supply to swap it, check here for parts.
Let me know if you require further assistance.
Aug 14, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
Close front cover
Unlikely the power supply. Sadly I can't think what causes that. I havent workrd on Toshiba for a couple of years now, but there is something else that causes that. Totally unrelated to the power supply or the switch. Have them call Toshiba support .
I am sorry I can't off hand remember the problem. But it is unlikely the power supply.
Jul 23, 2010 | Toshiba E-STUDIO 850 Copier
I want to change my LG front load washer so i will open to the right
Sorry, but the door on the washers are not reversible, only the dryer doors are reversible. I'd suggest using a low profile telescopic style dryer vent to allow you to put the washer on the left side without worrying about the dryer vent location. You can get longer dryer power cords if needed, and water supply extention hoses, or just longer hoses if needed. The drain hose is usually long enough to still reach the drain. I have done this many times.
Sep 28, 2009 | General Electric WCVH6800J Front Load...
HP LaserJet 4 will not power up. For several months, it has been taking longer and longer to power up. Flip the switch and nothing happens for minutes, then it cycles on. Now, nothing. No lights, no hum,...
The AC Power supply in your printer is out. The laserjet 4 and 4+ printers would both have long power up times when the power supply would start to die. You can get a replacement power supply very cheap now since the printers are older. We have them in stock as pulls from parts printers that should work just fine for you. We sell them for $30 plus shipping. We also have service manuals available if you need one. Let me know if you need more help.
Buddy
Corporate Computer
www.ccl-la.com
Sep 10, 2009 | HP LaserJet 4 plus Printer
Insignia tv will not turn on [ power up]
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 19, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
JVL Echo Encore 2 Entertainment Center Logo
88 people viewed this question
Top JVL Echo Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a JVL Echo Furniture Expert? Answer questions, earn points and help others
