On turning on my laptop, there is a continous beeping noise, maybe over 30 beeps. first there is 4 beeps, then 12 followed by other beeps
It is hard to count exactly how many beeps. also i noticed my battery power goes down quickly.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Suggest taking it to the shop and let it check. these warning beeps produce by the system that means, some of your hardware is not properly installed or not compatible.
thanks
Posted on Mar 29, 2014
How to fix the laptop which beeps continously?
there should be a pattern to the beeps, is it just constant beeping or 1 then 3 fast followed by 2 .
Jun 27, 2014 | Compaq Presario V5000 Laptop AC Adapter...
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
The capslock and the numlock leds r flashing continously. the screen is blankWhat's your problem?
The flashing and blinks tells the technician what is wrong with the computer. Most times it's the memory or video card. What is the make and model of your computer?
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 31, 2012 | HP Computers & Internet
Beep beep noise
Beep Beep noise when? Your memory is probably bad or the video card is bad.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 25, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
Continous beep when turned on
It identifiees Random Access Memory failure, Open the RAM cover at the bottom of the laptop, remove the RAM card/s from the slot, get the tissue, spray a bit of glass cleaner on tissue, and wipe the gold pins of the RAM. Reinstall and have fun.
Best of luck
Aug 07, 2009 | Computers & Internet
Beeping noise
Please check inside the machine to ensure that all packing material has been removed..cheers, John
Oct 20, 2007 | Brother ML-300 Typewriter
Laptop keeps beeping and not turning on
I think you may mean the Hard Disk light not floppy, although, if you have a floppy disc drive, check there's no floppy disc in it as it will stop the boot up. But if it's not the floppy, and the hard disc drive light stays on, possibly the hard drive is faulty, maybe damaged sectors. The other maybe is a possible memory fault, although the beep codes can only be identified if you know the motherboard make. Your rating are important.
Nov 22, 2006 | Gateway M350 Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
