Question about Xerox WorkCentre 7525 7530 7535 7545 7556 Black Toner 006R01513
Xerox workcentre 7530 printer does not start, just restarts again and again
I have a xerox 7530 printer when I turn it just stays on the screen "The system is in power cycle" and after a while restarts, again and again, that can be your help please
  • Jorge
    Jorge Mar 27, 2014
    as I can install a firmware from the USB port on the printer xerox workcentre 7530, as this does not finish loading, apparently this is the problem.
SOURCE: white screen on xerox xa7 19i
I had the same problem but fortunately I have two of these monitors so could fiddle with the menus on the working monitor until I could work out how to fix it on the one with the white screen problem. Here's what you do:-
With the monitor on and the white screen showing press MENU, then UP 7 times, then MENU and presto! Your screen will be back to normal.
What this does is change the input from ANALOG to DIGITAL (or vice versa!) either way this worked for me.
Posted on Jan 14, 2008
Avwrexit
  • 47 Answers
SOURCE: change the drum on xerox
Here is the pdf for the manual. Check out chapter 2 page 10 it has step by step instructions on installing the drum.. This should help in the removal of the drum also!
http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
Good luck and dont forget to rate my response!!
Posted on May 31, 2008
  • 2072 Answers
SOURCE: xerox workcentre m20i power off
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
Posted on Oct 16, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
leroyal
  • 2120 Answers
SOURCE: Xerox WorkCentre Pro 575 error message
Could be the tab that actuates the top cover switch is broken off.
The process unit is your drum,toner, and developer unit. It sits right under the top cover. Big black removeable cartridge.
Posted on Nov 03, 2008
Xerox 7328 touch screen not taken
I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working.
Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support
Thanks,
Sep 05, 2014 | Xerox WorkCentre 7328 Multifunction laser...
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
How do I scan a photo onto my laptop using a Xerox WorkCentre Pro Scanner?
Just attach the scanner to your laptop.Install the drivers of your scanner into your laptop and restart the laptop.
Now start scaning your documents..
Regards,
polysandy
Apr 06, 2010 | Xerox WorkCentre Pro 412 All-In-One Laser...
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Multifunction restarts repetedly
That is usually a bad main board. You can try removing the memory and reinstalling it...that fixes the problem sometimes. Also unplug your network cable and turn it on...data present when turning on some xerox models will cause problems.
Main Board is part number 140N63141
Jan 15, 2009 | Xerox WorkCentre 4150p - Multifunction -...
Xerox WorkCentre 7525 7530 7535 7545 7556 Black Toner 006R01513 Logo
98 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
