Question about Generac Measuring Tools & Sensors
Starts runs stops
Starts and runs about 10sec.s stops then starts and runs about 10 sec again on its own, will do this several times running a shorter time each time
    Master:
  • 452 Answers
Owen....sounds like fuel starvation check u have plenty fuel then clean ur fuel filter in line and in tank if u have 1, to check fuel is running ok remove fuel line the end thats connected to carb put in jar to catch fuel if runs ok thats good if slow flow or just dribbling blow through with air line then check again if ok reconnect
Posted on Jun 14, 2014
mydogisk
  • 50 Answers
SOURCE: Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Posted on Apr 13, 2009
  • 172 Answers
SOURCE: Generac 6500 1988 in R.V.Southwind Two things,
See if there is an oil pressure guage on the dash. When you start the machine it probably has a low oil pressure shutdown which shuts the engine off when you release the start button. This is an interlock. Watch the oil guage and keep the start button engaged until you see oil pressure, release the button and it will continue to run at that point. Your second issue may be a function of the choke. If you are having to choke the engine to start, you may have to play with the choke position to keep from overfueling the unit which may cause it to stall and possibly backfire as it has to much fuel to be burned on the compression stroke, and is igniting occasionally on the intake stroke. Hope this helps. Marvin
Posted on Jan 20, 2010
  • 25 Answers
SOURCE: saw runs great then bogs down 20 sec. after i
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Posted on Feb 11, 2010
puertobori
  • 7733 Answers
SOURCE: my honda 5000 runs great for a couple of hours
Gas or Spark Plug!
Posted on Oct 06, 2010
  • 130 Answers
SOURCE: my 60,000 btu kerosene heater runs for several
There may be a safety thermal cutout switch that is out of whack.
Posted on Jan 15, 2011
Husqvarna 125l carb problems
Check the fuel lines. Ethanol in the gas swells the old type fuel lines.
Jul 17, 2014 | Garden
Tip
Gm cars and trucks with security light on, veihcle will not start,stall after a...
a relearn of the key may help and is done with the ebrake up to keep the day time running lights off . put key in the ignition and turn it to the on position right before crank for 10sec. turn it off for 10 sec. then turn it back on for 10 mins. repeat two more times back off for 10 sec.and then back on for 10 mins. it iscruishle you try to keep with in the times or very close. 10 seconds and 10 minutes three times and that will relearn the key.
this will work for passlock 2 systems and newer.
on Jan 04, 2010 | Chevrolet Corvette Cars & Trucks
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
Grand am wont start. it is turning over tho. i tried the security fix (leaving it on for 10-20 mins, then off and trying) but it still won't start.
Hello: Try this, Turn key on, try to start, let k/switch come back to run, let set for 10min(security light out) turn key off 10sec, turnkey back on let set 10min, turn key off 10 sec, turn key on let set 10min. turn key off 10sec. turn key on start car if it doesn't start and the security light is flashing you have a passlock problem and it will require a new lock cylinder assembly and the above learn procedure.
Jan 27, 2011 | 2001 Pontiac Grand Am SE
My 2008 dodge grand caravan just started giving me problems when I go to start it. (colder weather) When I first try ti start it, it wants to start but it won't then next time it will start for 1/2 a sec...
Have someone check your fuel pump pressure....also your fuel pressure regulator.
A clogged fuel filter could restrict fuel flow enough to cause a low pressure condition. Once you have gotten it to run a bit, the pressure will build up and hold for subsequent re-starts.
Out of curiosity, how long can you let it sit shut off and still have it start normally. 1 or 2 hours? Longer? Overnight?
Dec 28, 2010 | 2008 Dodge Grand Caravan
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Measuring Tools & Sensors Logo
98 people viewed this question
Top Generac Measuring Tools & Sensors Experts
deton8 von Splosion
David Ellis Rhea
Lucy Angela
Lucy Angela
Are you a Generac Measuring Tool and Sensor Expert? Answer questions, earn points and help others
