Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How do i get behind the tub to clean
I think I have a sock behind the tub that keeps the drain from working. How do I get it out?
  • 1,511 Answers
If you need to get inside the enclosure to locate a sock; pull the washer away from the wall, expose the back side. With a hex tool or screw driver, remove the screws. Dislodge the back cover and look for the sock. The edges are SHARP, be aware of that fact. As a rule a sock is rarely the problem.
Posted on Mar 25, 2014
  • 4 more comments
  • kent phillips
    kent phillips Mar 25, 2014
    your correct, the sock wasn't the problem. It was the control board. fortunately I had an extra.
  • Dayton Computer
    Dayton Computer Mar 25, 2014
    Good, you solved the problem. Give us credit for trying to assist you, appreciate your reply.
  • kent phillips
    kent phillips Mar 26, 2014
    Well guys, i was a bit premature on my last comment.
  • kent phillips
    Sorry never hit the enter key til your ready to post. What i have now is a washer that overfills and still will not drain. part way throught the drain i get an SD code and then it just keeps filling til you have to turn it off to keep from runing over. Just finished dipping by hand for the second time. is it time to toss in the towel?
  • Dayton Computer
    Dayton Computer Mar 26, 2014
    So many reasons: Plugged exit drain line, pinched or bent tubing, etc. Check the Drain out where the hose sits by pouring water into the hole and se if it flows well. And/or Try this, take the drain line hose that sit in exit drain and pull it out of the line. Get a Vacumm with a hose that blows out into the room. Stick the blower hose into the Drain Hose. Force it in so air will not escape around the sides. Turn on the Vacuum and se if you can get forced air into the drain hoses pump area. Keep looking at the pump if that fails. Soemthing is blocking the pump ot the pump failed.
  • Dayton Computer
    Excuse spelling errors!
My bleach container does not empty at all also my cloths don't seem to be getting very clean and my towels have a weird odor to them after being used for just one time. I get the cloths out of the washer...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((%%&&
Sep 18, 2010 | LG WD-16115FD Front Load Washer
The washer has an odor...I think it is the fabric softener build-up. How can I clean this?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Sep 10, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a whirlpool duet front loading washing machine model #GHW9400PLO. I have been noticing musty odor from my machine. After inspecting the washer, i noticed an article of clothing (small sock) has...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!@
Aug 04, 2010 | Whirlpool GHW9400 Front Load Washer
Odor in washer tub
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
Apr 05, 2010 | Speed Queen AWS45NW Top Load Washer
Maytag Neptune Superstack water accumulation and odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!%5
Jan 27, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
I can not get rid of a mildew smell in the washer. I have cleaned the rubber tubing around, I have also used the tablets to eliminate mildew in washers - did not work
Oct 13, 2009 | Kenmore Washing Machines
I've had my Whirlpool Duet for a couple of years now and in the past 6 months or so, I have noticed when I open it after it sits empty it smells sour like water isn't pumping completely out. I have checked...
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew in the tub. clothes now smell.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
My Elite washer has a musty odor. I have run an
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
118 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
