Question about Premier Range. 36 in. Freestanding Sealed Burner Gas Range in Stainless Steel P36S348BP
OVEN When I light the oven it turns on but only heats to about 200 degrees then shuts off.
    Top Expert:
  • Premier Master
  • 42,828 Answers
Is that ferenhit or celcious over 400 if celcious suspect thermocouple if
Posted on Apr 16, 2015
Oven won't pre-heat or reach bake temp?
Could be the oven thermostat, that's the long skinny tube with the thin copper pipe coming off it follow it back to the oven knob. Test it by putting a putting an oven thermometer in and compare the difference they only cost a few dollars at good home ware shops.
May 07, 2014 | Maytag MGR5751AD Gas Kitchen Range
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
GE JGSP31GER Gas Oven doesn't heat up hot enough
The part your talking about used to run about $275 which is pretty high for a free standing range but the cost of it isn't important. The reason why is that they no longer make that part anymore and when i looked it up I got NLA which means no longer available. You may get lucky and find a company that possibly has one still in stock, but there is no way that it will come with a warranty, so if its a dud when you get it your stuck with it. I would invest my money in something I could fix when it came time to.
Jun 19, 2012 | GE Kitchen Ranges
Don't have the instructions on how to clean the oven
hello,
Not to worry - cleaning your oven is not the all-day chore it used to be.
1.Remove oven racks and soak them in soapy water.
2.Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean.
3."Let the oven do its work; it will heat for several hours, charring off baked-on foods.
easy process
1.Remove oven racks and place them in soapy water to soak.
2.Preheat oven to 200 degrees.
3.Turn the oven off and spray the inside with oven cleaners.
4.Allow to sit for 10minutes.
5. Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
6.Dry with a soft cloth.
Please do any of this carefully.
thank you and thanks for using fixya.
  • Step 2 Preheat oven to 200 degrees.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0wJaVrOXb
    Aug 11, 2010 | Kitchen Ranges
    Oven heats to 200 and indicator dings
    Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
    Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
    Oven works when it feels like it.
    The ignitor is weak and not lighting the oven consistently. Need to replace the ignitor.
    Nov 16, 2007 | Amana RanARG7302 Gas Kitchen Range
    Oven taking a long timt to heat to temperature
    Try shutting off the breaker for about 10 minutes - then bring the power back on
    Sep 20, 2007 | GE Profile JT912 Electric Single Oven
    Oven not working
    Per this page (http://www.repairclinic.com/0078.asp#Tappan), it sounds like you need to replace your oven temperature sensor.
    Feb 23, 2007 | Tappan TGF363 Gas Kitchen Range
    Premier Range. 36 in. Freestanding Sealed Burner Gas Range in Stainless Steel P36S348BP Logo
    97 people viewed this question
    Top Premier Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
