Question about Garmin StreetPilot c340 GPS Receiver
When programming an address, the state won't chnage to any state. it stays in the stay i am currently in. how do i get this to allow programming of any state?
I cant program any states except the one i am in
  • doug rolon
    doug rolon Mar 27, 2014
    when you program an address in another state that you are not currently in, my gps won't allow me to change the current state on the screen where it says the state and county option. i'm locked into only programming destinations in my current state
marcelbakker
  • 174 Answers
SOURCE: traveling out of home state and cant program address
Hmmm, do you have all states (full coverage), if not you need an upgrade to unlock full us coverage, if yes, select navigate to / state / city / street / number. Can't be that difficult can it?
Posted on Jun 10, 2008
SOURCE: Garmin forerunner 301
oops, i meant i know its NOT the oxidation problem
Posted on Aug 01, 2008
SOURCE: Why won't the key pad allow me to type in the address?
click on settings on the right of the screen, then on map, then on map info at the bottom of the screen, and tick the box for city navigator europe NT 2008 and this should get you going, this drove my husband crazy for days and i just stumbled onto it,good luck
Posted on Dec 29, 2008
  • 1111 Answers
SOURCE: If your home state is programmed in for
go to the where to tab, then address, then select state. you should have to options there. one is your state, the other is other states.
bill
Posted on Oct 20, 2009
  • 589 Answers
SOURCE: When trying to program in an address the Nuvi
I would make sure that your Ciy Navigator map is selected
go to Tools...Settings....Map....on bottom of screen press Map Info....make sure a check mark is in the City Navigator North American NT
Posted on Nov 09, 2010
My rv fridge will lite but goes out as soon as the ignition cycle stops
You didn't state the Brand or Model of your refrigerator but it sounds like your flame sensor isn't working.
rv refrigerator won stay lit YouTube
Oct 14, 2014 | Heating & Cooling
CAN YOU GET SHORT TERM REGO FOR CAR
the regulations in QLD state that the vehicle has to be registered in QLD almost immediately if you have a permanent address in this state. The exceptions are service personal who are allowed to keep current rego until it runs out and then it has to be registered in QLD. You will need to have a QLD road worthy done and there is a six month rego period available. Any rego period is refundable less 1 month So if you have it regoed for 6 months , stayed for a month then surrender the plates you may claim 4 months refund. Best check it out at a main roads office near you as regulations change on a regular basis.
May 16, 2014 | 2014 Chevrolet Corvette Stingray
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Toshiba L655-s5117 won't stay on
CPU is over heating needs to be re greased not an easy job would recommend taking it to a shop for repair using it in this state can cause critical irreproachable damage
Feb 11, 2012 | Toshiba Satellite Laptop / Intel Core i3...
Malta dryer burner won't stay lit
usually a clogged vent or I've seem a coil go bad that allows it to light once but not the second time in the cycle
Feb 01, 2012 | Maytag Dryers
I have a 2002 ttr 225 and it won't stay on it
Hi Pompa_elias, I am sorry you can't find the first and best tool you ever bought for your Yamaha but despair not for a mere $15.00 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
2002 Yamaha Motorcycle Service Repair Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 23, 2012 | 2002 Yamaha TT-R 225
How do i activate the wireless connection on my daughter msi u100 435uk netbook as it won,t come on after ste used a pay as you go dongle when staying with friends who had no internet
go intocontrol paneland select add/remove programs or programs and features and find the payg dongle software and uninstall it then restart the netbook that should remove the dialup connection and allow you to connect back to your wireless.
If you need any more help leave a message
Mar 04, 2011 | MSI Wind U100 Netbook
Grill will not stay on when I release the knob, the gas goes out
hi, sounds like the thermocouple, when heated it produces a small current to allow the gas valve to stay energised. they can break, so the current cannot pass through. hope this helps
Apr 10, 2010 | Ovens
Can you direct me to a user guide? I've moved to
The advance button send the current program to the next state. So if you have 3 on - off cycles programmed per day and you are currently at the second on cycle then by pressing advance the program moves to the second off part of the cycle and will stay off until the next on command time is reached. So if you are on Heating the advance will only affect the heating. Similarly if you are on Water then it will only advance the water program.
Sep 29, 2009 | Hardware & Accessories
Garmin StreetPilot c340 GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
