Question about HP Pavilion DV6700T Notebook PC
Same issue. Dies on boot. Doesn't even seem to load BIOS.
Just a black screen and a few seconds.
    President:
  • 2,653 Answers
Very common with these models.
Try reseatting / swapping the memory modules.
Booting the computer with the battery, hard drive and dvd drive disconnected.
Let me know what happens. You're probably having a problem with the motherboard and there is an extended warranty fix program available, but let's check the above things first.
Posted on Jun 15, 2009
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
I have a Asus Rampage Formula board w/ 4gig mem, was running a BFG GTX 260 max core nvida card , win XP pro 32 bit sp4. I have had no issues for about 1yr then when the computer would run for a few hrs the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | ASUS MB RAMPAGE FORMULA 775 X48 RT...
My dell inspiron seems to be stuck in hibernation mode. The screen flashes on for just a few seconds when i turn on the computer then the screen goes black. What can i do?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
don
Feb 23, 2011 | Dell Inspiron 1545 Notebook
I have a Vaio PCV-W20, and a few months ago the screen went black. The problem is that now I only get a visible screen for a few seconds and it goes black again. For example this is what I see when the...
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084 -
Jul 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Toshiba x200 black screen of death. One long beep, twoo short beeps. Help please.
The error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
Do you have access to bios?
If you have access to Bios, I suggest you to load optimal defaults and try booting, It must fix your issue.
If you do not have access to Bios, I suggest you to remove the recently added hardware (if any) and try booting.
If there is no recently added hardware, It-seems that Video (Mono/CGA Display Circuitry) issue, I suggest you to contact near by service center.
Regards
May 24, 2010 | Toshiba Satellite X200-AA3 Notebook
Gateway 5228 wont boot no lights on keyboard
does it load the bios screen? Does it get to the windows load screens if it does go to the bios screen? Does the computer power on at all?
Sometimes what happens is the bios chip can be faulty or die and this will have to be replaced to fix the issue. If the computer is not powering on then it is more than likely a power supply issue.
(just in case, you might want to make sure that all of the adapters that come from the power supply are connected to the motherboard as well)
Sep 30, 2009 | Gateway Computers & Internet
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
HP Pavilion DV6700T Notebook PC Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
