Question about Hunter Ceiling Fan Remote Transmitter 85095-01
Have 2007 vibe will not reverse
Went to, store parked car came back start car will not backup
Why are there problems with reverse?
The reverse sylinoid is probably bad and needs replaced
Apr 19, 2016 | 2007 Mazda MAZDA5
My neutral light is flashing on my 2007 Mitsubishi endeavor, it will go in reverse but won't go in drive. What can be the problem?
Stuck Transmission Lock - Mitsubishi-Forums.com
www.mitsubishi-forums.com > ... > 2G (2007+) Outlander
Feb 22, 2008 - 5 posts - ‎4 authors
Drives: 1997 Outlander LS, 2007 Series 3 380 SX ... Hopefully the heads up will help one/some of you out if you ... This morning I jumped into my 2007 Outlander (Aussie Spec with the CVT) and I couldn't move the gear ... I couldn't find anything in the manual about it, but a Google search brought me here.
Getting Into Reverse Gear - Mitsubishi-Forums.com
www.mitsubishi-forums.com > ... > Colt & Mirage Forum > 2003+ Colt
Mar 17, 2007 - 15 posts - ‎10 authors
go to another car dealer with the same model and a manual ask for a test ...QUOTE(stevansam @ Mar 19 2007, 07:34 AM) ... the dealer won't take the car back because it's not a fault of the car but a ... I also have a Renault megane and at workdrive a Ford pick-up, which both have syncho in reverse, I can't ...
Adjust Digital Transmission Range Sensor - YouTube
? 0:42
https://www.youtube.com/watch?v=FyiGxhkV-VM
Mar 27, 2010 - Uploaded by Alexander Cameron
If the DTR is not adjusted properly, you will get a no-start situation. ... when I am in drive and shift to reverse my backup lights dont work but if I put into park and not even all the way into park and go reverse they work. ... Hi I changed the solenoid
Jan 10, 2016 | Mitsubishi Cars & Trucks
2007 pontiac torrent
sounds more like a broken cv shaft. have a look under there while someone puts it in drive or reverse.
Oct 18, 2017 | Cars & Trucks
2004 Pontiac Vibe
the nuetral safety switch is bad or linkage is out--a haynes manual xplains this-sold in partstore--always use jackstands under a car-jack alone wil move and fall
Feb 03, 2014 | Cars & Trucks
Transmission for 1999 cara van
did you check the fluid in the transmissin it could be low or also it could need a new transmission filter i wouldnt try to drive it it anymore without checkin or changin it because it will burn it up
Feb 16, 2013 | 1999 Dodge Grand Caravan
My 2010 impala is starting, but the shift stick
It sounds like the Park/ Brake Interlock is not working, your car is a 2010 it should be covered under warranty still, take it back to the dealer and let them fix it.
May 27, 2010 | 2006 Chevrolet Impala
Rear wheel locked up
put car in reverse and very gently try to back up,it is possible the the brakes have locked on (rusty )low miles will cause brakes rust very quickly.a few stop/starts will clear them.
Mar 19, 2010 | 2007 Toyota Corolla
No reverse all of a sudden
check power to the reverse shift solinoid
Sep 30, 2009 | 2002 Chevrolet Impala
Engine light stays on , auto tranny now shifts hard
if you had the fluid changed they probably used the wrong fluid only use type iv fluid available through gm or toyota
Aug 25, 2009 | 2005 Pontiac Vibe
Dryers Logo
18 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
