Question about Tricity Bendix AW1000W Front Load Washer
Washing Machine wont spin out...
My Tricity Bendix AW1000W washes as normal but wont spin out at the end of the cycle. Ive checked he brushes which are fine. Ive manually drained it. Still no joy. The odd time it spins, others it wont. Im wondering if its a computer related issue? Any thoughts?
5 Suggested Answers
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
barkencoa
  • 3463 Answers
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Posted on Dec 12, 2008
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a Tricity Bendix AW1000W. The drum will not
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
Posted on Nov 25, 2009
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
It won't go into the spin cycle
Have you checked that the filter at the bottom r/h of the machine is clear and that the pump turns freely if that is ok make sure that the drain pipe is not blocked or kinked.If you are still having problems then it could be the motor,brushes or belt.
Good luck.
Apr 25, 2010 | Tricity Bendix AW1000W Front Load Washer
How to get a spin cycle
I am basing this on a 2005 model AW1000W. To get a wash cycle with the maximum spin at the end use progs.1,2,3and 4.All the others only have a short spin.Hope that helped.
Good luck.
Apr 13, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bedix spin query
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Tricity Bendix AW1000W Front Load Washer
My servis washing machine turns and empties but wont spin machine isnt spinning
I suggest you remove motor and check the carbon brushes fitted at the end of the motor, if they are less than 2-3mm long ,they need replacing.
Thanks.
Jan 04, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity bendix aw1400w
not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
May 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
