Question about Keurig B60 Coffee Maker
Not ready message appears than it shuts itself off and i can't get into the menu
Can't get into the menu because it won't allow me, it just shuts off after a few seconds of displaying the not ready message.
  • 1,511 Answers
Turn off the Autostart button.
Posted on Mar 25, 2014
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: menu screen keeps popping up instead of "ready to
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101;;'
Posted on Sep 05, 2011
heatman101
  • 43501 Answers
SOURCE: My coffeemaker turns on, but doesn't get to
heatman101
How do I reset a hp LaserJet 3055
Soft reset:
1. Press Menu. 2. Simultaneously press and then release the * button and the # button to open the developer's menu. 3. Press the < or > button until the message REINIT FFS appears on the second line of the control panel display. 4. Press . 5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready. 6. When the Ready message appears on the control-panel display, press Cancel to exit the developer's menu.
NVRAM reset:
1. Turn off the all-in-one. 2. Press and hold down the * and 5 buttons. 3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When prompted, set the language and telecom country/region. 6. Allow the all-in-one to return to Ready before using it.
Best of luck..
Oct 12, 2014 | HP LaserJet Office Equipment & Supplies
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
The TV shuts off by itself.
Verify you are installing the lamp door correctly. Some units require a swinging motion for installation. Insert bottom, swing top of lamp door into place. Or, you may just need a new lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
HP 3055 Print funny "asci" type characters
Hi koos169:
Try these steps
Printing a configuration report, demonstration page, or menu
structure
1.
Press Menu.
2. Use the < or > button to select Reports, and then press .
3. Use the < or > button to select Config report , Demo page, or Menu structure, and then press
. The product exits the menu settings and prints the report.
Performing a soft reset
To perform a soft reset
1.
Press Menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the controlpanel
display.
4. Press .
developer's menu.
Hope this helps
May 19, 2009 | HP LaserJet 3055 All-In-One Printer
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
control-panel display.
4. Press MENU/ENTER.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
Nov 25, 2008 | Nikon COOLPIX L5 Digital Camera
'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Jul 30, 2008 | Dell 3000cn Laser Printer
83 PHOTODEV CART MISSING
To specify which supply has been replaced:
  1. Make sure the printer is on and the Ready message is displayed.
  2. Press and release Menu until you see Supplies Menu, and then press Select.
  3. Press and release Menu until you see Replace Supplies, and then press Select.
  4. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  5. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  6. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  7. Press and release Return until the printer returns to the Ready state.
Oct 15, 2007 | Lexmark C510 Laser Printer
Keurig B60 Coffee Maker Logo
232 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
