Question about Nordic Track NordicTrack C2150 Treadmill
Belt not working
The computer board turns on and starts tracking distance but the belt doesn't move.
  • alicia
    alicia Mar 25, 2014
    I should add that I am not getting an error message. The computer board seems to think everything is working fine.
  • 1,511 Answers
I believe your talking about the Controller, not a computer board. This device may turn on, however; the instructions and sequence of activity will not work. Many reasons for this to happen; and usually the problem is traced back to a power surge. Major components and equipment need to be plugged into a UPS (Uninhabitable Power Supply) with special protection to avoid damage to vital electronics. If plugged into the wall (directly) there are no protection devices and current can pass through a device and damage the controll unit.
Posted on Mar 25, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
Please run the software calibration that coming with your equipment, see the instructin under the Hood motor, and follow the steps. or user manuals.This will guide your for diagnose and troubleshooting.
See the attached block diagram for troubleshooting and diagnose that I did prepare for customers.sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 15, 2012
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
My treadmill turns on, but doesn't start
1) LUBE the deck belt, this happen by lack of maintenance, maybe you have deck worn.
2) LUBE the rollers bearing too.
3) measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jul 23, 2012 | Nordic Track NordicTrack T7 si Treadmill
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
My nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
God bless you.
ernesto cuadra
Feb 13, 2012 | Nordic Track NordicTrack Treadmill, A2550
Everything works on the display but when you start the track it doesn't move. If you start walking on the track it will dsiplay your speed but not run by itself
Remove the front cover and check to see if the RED led is solid.
4 x screws on the front and two underneath the belt to the sides.
Sep 10, 2011 | Epic View 550 Treadmill
Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Belt on nordic track exp 1000 not moving today but worked this week. machine turns on though
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Nov 12, 2009 | Nordic Track /proform Treadmill...
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack C2150 Treadmill Logo
89 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
