Question about Emerson EWL3706 37 in. LCD Television
Shuts off after 5min or 15 sec. when warm good pichure and sound when on
  • Dayton Computer
    Dayton Computer Mar 27, 2014
    If you found cold solder joints (open spaces) then yes, they need to be reheated with a 25 Watt soldering iron. Too much heat could cause a solder run whereby the lead composition spreads to associated components and causes a short circuit or burns out vital parts. Remember, if a board shows any sign of stress it can break or slightly crack at other points along the way. Usually, it is best to replace the defective board with a factory replacement if it is a reasonable solution.
  • Emerson Master
  • 1,511 Answers
I hope my reply is of help to you. LH
Posted on Mar 27, 2014
  • Emerson Master
  • 1,511 Answers
There is a short on the video controller and when it heats up, the circuit opens and disconnects or what we call a short circuit. A technician can locate that point with his/her test equipment and do a repiair.
Posted on Mar 25, 2014
Testimonial: "ok so ive fixed auto dash clusters which have the solder joints crack and need to be resoldered is this what u mean?"
  • Dayton Computer
Sony tv fault codes
This could be a fan error. But Good "Sony TV error codes" for more info
Sep 09, 2014 | Televison & Video
Car starts but will not stay running
Sounds like your fuel pressure regulator. Check vacuum connection at fuel pressure regulator. That's the only easy check. the rest may have to be trial and error, i.e replacing fuel pressure regulator and then fuel pump if that doesn't work.
Mar 04, 2014 | Volvo S90 Cars & Trucks
1kz engine light comes
have you tried to deep clean your throttle body and take the pos+ off the battery and wait 15 sec. and put it back on and start the car and wait 5min. and see if it comes back on
May 19, 2013 | Cars & Trucks
Motor egy90hlp into Whirlpool ed5fhgxkt04 start 10 sec, ang goes off 5min. come back another 10 sec. and do this cycle all day...also the compresor click on and click off sound, please helme...Alex..
HI,
From your description you have a starting problem with your compressor, this unit is called a relay. If the model number is correct, click on the relay link above and this is what your pat looks like that you need to replace.
Good Luck
Oct 12, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I installed a Woods 59720 timer switch to control a small bathroom fan. First time I turned it on 5min cycle it worked fine. Now, it runs only 10-15 seconds, then turns off. Set for maximum 30 minutes, it...
I looked it up and it sounds like your unit is defective. It should run for 5, 10, 15, or 30 minutes. There are no "seconds" options. The timer chip/module may be defective.
Gary
Sep 04, 2011 | Woods 59720 Automatic Wall Switch Timer...
It's like she's "charging".
SOUNDS LIKE A COLD SOLDER JOINT OR A BAD COMPONENT WHEN IT WARMS UP THATS WHEN IT STARTS ..TAKE OFF THE COVER SO THAT YOU CAN SEE THE SOLDER SIDE OF THE BOARD PUT POWER TO THE RADIO AND WHEN IT WARMS UP AND SHUTS DOWN TAKE A LITTLE PIECE OF WOOD OR PLASTIC AND PROBE ALL THE SOLDER CONNECTIONS TO CHECK FOR A COLD SOLDER JOINT IT MAY BE GRAY IN COLOR MAY NOT.. SEE IF IT GOES ON AND OFF.. IF SO RESOLDER THAT SOLDER JOINT.......IF THIS DOES NOT WORK ....PICK UP SOME FREEZE SPRAY AND SPRAY IT ON THE COMPONENT'S ON THE OTHER SIDE OF THE BOARD THIS IS WHAT A SERVICE PLACE WILL DO IF THAT DOES NOT WORK NOW BRING IT TO A SERVICE AND LET THEM SCRATCH THERE HEAD GOOD LUCK
Feb 16, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Emerson EWL3706 37 in. LCD Television Logo
44 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
