Question about Sunbeam Steam Master 4055 Iron
Setting for steam
Need to know how to set for steam
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Www.laundry.manualsonline.com has free manual
Posted on Mar 27, 2015
Steam iron not steaming was working ok one min then no steam
If the temperature dial is not set high enough, or the thermostat is faulty and setting the cut-off temperature too low, some steam irons will fill up their steam chamber in their soleplates completely with water and stop steaming, until the temperature returns above what's needed to continously generate steam.
Nov 26, 2017 | Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
I want to know how to clean my Rowenta Advancer DZ9080 steam iron. When I use the shot of steam, ''stuff'' comes out of the holes.
You can use ordinary white vinegar. Use about 1/4 cup or so mixed with 2 cups water. Fill iron with this solution and operate it at full steam setting(high as possible) Set a folded towel(may want to use an old one)iron on the towel and operate the steam device until all the liquid is gone. This may clear some of the scale build up. There are Generic brands available at the stores made especially for irons, but vinegar is the most enviro friendly and is cheap.
Feb 20, 2010 | Irons
How to use steam iron
Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
Feb 23, 2008 | Micro Pro 7599 Iron
No Steam
Your iron will only steam when it has reached the desired tempeture. When the yellow/orange light comes on and the dial has been set for cotton or linen it should steam, when you lower the top and push the steam lever
Nov 01, 2007 | Singer CSP1 Iron
Sunbeam Steam Master 4055 Iron Logo
121 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
