Question about Vacuums
Change Belt I've changed the belt 3 times and they keep snapping. THis time however, the brush won't turn
  • Vacuums Master
  • 1,467 Answers
Hair and debris works it's way under the end caps of the brush roll causing a restriction. If you can't clean the debris out and get the brush roll spinning greenly you may need to replace the brush roll.
Posted on Mar 26, 2014
  • 27 Answers
SOURCE: belt burning
the beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Posted on Jun 15, 2007
ukvacfan
  • 328 Answers
SOURCE: HOw to change the Belt on a Vax VX1 Model
There is a brush reset button on the handle. Check to see if this has been pushed in. Also check to see that the brush slider has also been switched on. Usually belts are protected on this model but you should be able to remove the bottom sole plate where the base of the vacuum is (and beater bar). If the belt cover can't be removed then it has to be repaired professionally.
Posted on Mar 27, 2009
  • 389 Answers
SOURCE: how to change a drive belt
OK, here goes... NOTE - any use of the words LEFT and RIGHT assume that you are looking from the REAR of the machine. NOTE ALSO - the machine has two toothed belts, it makes sense to change both while you're at it. Incidentally, this is a job you shouldn't have to do very often - Sebo belts usually last at least 10 years.
STEP 1. Separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
STEP 2. Turn the base upside-down and undo the FOUR DEEPLY-RECESSED SCREWS. All the surface-mounted screws are irrelevant to this job.
STEP 3. Turn the complete base right-way up, release the foot pedal and move the vacuum tubes out of vertical. The top cover will then lift off. You will see there are two belts - the pulley device between the motor and the brush roller is the sensor that measures the drag on the brushes and operates the automatic height adjuster to maintain constant drag. To the right of that double pulley is the electronic circuit board - note that it has a sensor that locates within the pulley device, be careful not to damage it.
STEP 4. At the left end of the motor cover, the drive cog is concealed by a small cover. Lift this cover out vertically, noting how it locates in the frame for when you come to put it back. Next, although not essential, it helps to remove the metal lever because if it falls out when you're not looking you may later be uncertain about how to locate the small coil spring. So slide that lever out towards the motor, noting how the spring locates.
STEP 5. Undo the two screws holding the circuit board (take care the washers don't slip away). Then undo the four screws holding the double pulley. Once that's free, you'll be able to change the belts.
Re-assembly is simply the reverse of the above process.
If you need more help, just ask. Please remember to rate this response.
Posted on Oct 20, 2009
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
SOURCE: Repalcement of belt on Hoover F7425-900 Steam Cleaner
To help out here the hood has 6 screws on the underside of the machine and 2 post snaps at the rear of the hood. They pop out when lifting the rear of the hood. The air motor is as described above, 2 on bottom and 2 on top. When removed the air motor again has 2 screws on the cover of the gear set and a couple clips which come loose readily when the screws are removed. This exposes the gear set. Remove the gears and free the air motor shaft. Clean, lubricate and reassemble. You should be good to go. The Air motor is the only weak link in the machine. The bearings seize due to exposure as moist air is pulled through the air motor to drive the gear set. Great idea! Hoover should have used a stainless drive gear and bearings or a plastic bearing that would hold up to the RPM of the motor. Regardless, as is it will be plagued with the problem for the life of the machine unless you upgrade. Hoover may have solved this for all I know. Hint: The motor will not create any torque until the suction tank is in place. Oh, and keep the screen clean. That is the motor intake.
Posted on Jan 27, 2010
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Belt keeps coming off
Hi There,
Most likely 1 of 3 problems.
1. The belt is stretched and so is just slipping off
Solution change the belt
2. THe brush roller has siezed bearings so brush cant turn properly so belt is slipping off the shaft.
Solution - check see if roller turns easily by hand if not change the bearings.
3. THe motor has twisted in its body due to cracked housing or worn rubber seats.
Solution- Depending on your skill and age of vacuum replace the housing or the vacuum.
If you need parts for your vacuum visit www.vacuumspot.com.au
May 13, 2012 | Oreck XL Ultra Bagged Upright Vacuum
I need instructions on how to change the belt on my Hoover Model U4264-930 vaccum.
Tool Needed, flat head screwdriver (larger one works a little better). Serious Safety Precaution: Make sure unit is unplugged. Preliminary: Check: that nothing is caught like threads etc, preventing roller brush from turning. I've had this model vacuum 10 years and have pulled threads out countless times. However it still has the original belt on it. To change belt: 1.) There is a plastic plate underneath roller, towards front.. Pry the 3 tabs at front, the plate hinges downward slightly (to clear the front tabs). Next, there are 2 little clips at bottom of plate. Insert screw driver at each of these clips to fully release the plate the rest of the way. (Or it may even come off without having to pry back on these. The plastic clips need pushed towards front, to clear the ridge that catches towards the back). Pry one, then the other, clip forward, while gently pulling the plate the rest of the way out. (Gentle prying will assure it will snap back together OK, so you still get a good seal.) You now should see the whole roller brush. 2.) Remove the shell/motor cover: To do this, a.) pull off the rug height adjuster lever, and take not where you put it so you won't loose it. b.) push foot release down and keep vacuum bag in the vacuuming/hinged/operating position (not the upright/locked position), and position cleaner on it's side, or upside down. c. Pry around the bottom edge, starting at right corner, then go around, prying in about 4 different places. Shell/motor cover will now easily pull off (upward and out towards front), exposing motor shaft and light bulb. 3.) remove belt from motor shaft. 4. slide roller and old belt out the bottom. 5.) remove old and place new belt on roller 6.) slide roller back into place. 7.) wrap other end of belt on motor shaft. 8.) shell cover, rug height adjuster knob, and bottom plate snap back into place. check that roller turns without much effort. 9.) It now should be ready to plug in and vacuum.
Aug 21, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
How do you change a belt on a dyson DC07
Turn vacuum over so you can see the brush.
Using a standard screwdriver, undo the three fasteners just behind the brush.
Remove the base plate.
Remove the belt.
Remove roller brush.
Place new belt on roller brush and center it in position.
Feed belt through the hole, and return brush to position.
Ensure the brush ends are located in the slots correctly.
Pull the belt over the motor shaft.
Rotate the brush a few times to ensure belt is centered and secure.
Replace the base plate, tighten fasteners, and rotate the brush a few more times to make sure it turns properly and the belt isn't caught.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I change my belt?
1. Turn vacuum over so base of powerhead is facing up.
2. Remove the two screws near the roller.
3. Release the two hooks over the brush by pushing outward.
4. Gently lift and remove the plate.
5. Lift and remove brush roller.
6. Remove belt.
7. Place belt over roller in the area with no bristles.
8. Insert brush back into holder and loop belt over motor shaft.
9. Rotate the roller a few times to make sure the belt is properly positioned.
10. Replace the plate over roller, making sure the front tabs line up with the slots on the base.
11. Flip down to secure hooks.
12. Press down on plate to secure it.
13. Replace screws.
14. Turn roller a few times.
And you're done.
The manual with illustrations and instructions can be found using the below link.
http://www.dirtdevil.com/search.aspx?q=UD40135&type=3
Jan 21, 2011 | Dirt Devil Featherlight Bagless Upright...
The belt on my vacuum cleaner model 6596 bissel powerforce bagless turbo keeps breaking. As soon as I put on a new belt and start it up the belt snaps. It is the durabelt meant for this vacuum model....
I would guess you aren't centering the belt correctly, thus it's edge is caught between the brush and another solid object, causing the breakage.
When you get the belt on the the brush and the brush back in place, turn the brush a few times by hand to make sure it's not catching on anything. After you get the powerhead put back together, do this again. It's a common problem if the powerhead isn't assembled correctly.
Here's a video clip from the Bissell site demonstrating changing the belt.
http://www.bissell.com/how-to-videos/replace-brush-belt-vacuums/
Jan 08, 2011 | Bissell 6596 Bagless Upright Vacuum
Reinstalling beater bar... making a noise like its not in the correct slot.
Getting the sole plate back on correctly and the beater brush in the correct slot should help. The clucth is engaging and keeping the motor from overheating is the noise you are hearing.
bearings in the brushroll might be siezing. If you start snapping belts, change the brushroll. the roller brush that most likely needs to be cleaned,clean the hair from the brush and under the belt and make sure the bar is positioned in the vacuum properly and turns easily. Your problem could be the clutch unit what has probably happened is either the clutch plates are warn, or the 3 balls in the clutch have warn a large grove in there fixing plate or the plastic hub that the brush roller to clutch belts runs on has melted this hub melting is the most common of all clutch faults.
There are no spares available for repairing the clutch other than the motor to clutch belt & the clutch to brush belt. Here is a diagram to help you
Nov 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt won't stay on
A belt will slip off because it is stretched, or the brush bearings are worn, or the motor drive shaft is misaligned.
Hoover belts fit snug.
After as little as week they begin to stretch. Even though they are not broken, they will spin loose. IF you can stop the brush with little effort and the belt keeps moving the belt is stretched. Do not buy a belt buy size, buy it by model. But 2 and store your spare under the hood of the vac if possible.For best cleaning results,change every 3-4 months if you vacuum weekly. 6 months at most.
Most times your old belt will be stretched as much as 30% oversize. If it looks shiny inside it has likely been slipping.
Before reinstalling check that your brush rolls freely and clean the bearings at the end of the brush roll.. Once reinstalled check it again before turning on the vac.
Sep 13, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
