Key will not start engine 2002 ford explower
Every thing all lights door locks work
SOURCE: Ford F150 Pickup 2005 power doors unlock but will not lock
I had almost the identical problem on my 2005 F150 FX4 Extended cab last weekend. The power door locks would not lock using the keypad, remotes, or door buttons. Almost all other functions worked correctly. The doors unlocked, the radio delay functioned, and the interior lights dimmed. When I used the remote the horn would beep twice indicating that a door was open even there was no message on the message center that a door was open. When I used the keypad or remote, I could hear a soft click from behind the seat. I think it was coming from the body security module or body security module - whatever Ford is calling it this year. I pulled the fuse for the Power Door Locks(BSM). As I removed it, I heard a soft click - sort of like a relay resetting. It may have come from the VSM/BSM. It may have possibly been a stuck actuator releasing. I don't think so. It wasn't that load. In any case, everything is functioning correctly now.
Tracy
Posted on Nov 20, 2008
SOURCE: 1999 Ford Explorer Door Locks
Unfortunately, This is a very common problem with Ford Explorers! Ford replaces the locks when it encounters this issue. I managed to unseize my passanger door and tailgate lock, but the drivers door lock is broken beyond repair. You can purchase new remotes for your explorer and program them very easily. Just google ford key fobs...
Posted on Jan 25, 2009
  • 23 Answers
SOURCE: 2001 ford escape won't start
immobilizer has kicked in
Posted on Feb 24, 2009
SOURCE: 2002 BMW 325 - key locked in trunk
There are several suggestions out there on how to retrieve BMW keys from the trunk. Many of the ways I tried failed, and it takes 2 to 3 days to get a new key made up. In the coupe there is the center piece in the back seat that folds down. Then on the back wall there is material that will fold down that is held up with Velcro. Behind that you will find a rubber insulation that is mostly cut and looks like a door, but not all the way. Carefully cut the rubber to remove the piece. Now you will find a metal wall, but there is a large piece that is tack welded on. I got turned around and kicked it with the bottom of my foot and got 3 sides loose. Then a softball bat knocked the final side loose. Pull that out and trash it, the final barrier is the insulation that is held in place with plastic clips that can just be pushed down. After that you can a pretty large hole to work through and get the keys. Just put everything back in place other than the metal plate and you will never know anything was done.
Posted on Mar 30, 2009
Murphybanton
  • 2004 Answers
SOURCE: how do I program remote to unlock the doors of 2002 ford taurus?
Come on chat wherein you can stand close to the car while I guide you.
I am Murphybanton.
I am online now.
Posted on Oct 05, 2009
How can i start my 2000 ford escort when i lost my key
If your Ford Escort was made in the years 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, or 2003, then you have one key that starts the engine, unlocks the doors and trunk. You can find the key code information stamp on the passenger door lock. You can take this key code to a locksmith shop and have them cut you a new key by the key code.
Quoted from Denver Locksmith.
Sep 22, 2017 | Ford Cars & Trucks
2002 ford focus call won't start and the door locks don't work
put key in ignition turn to number 2 press the fob until doors lock if they dont lock then the transponder in the key fog has come lose or fell out. will need to be soldered back in. happens if you keep dropping your keys..
Jan 05, 2014 | Worldwide 2002 Ford Focus ZTS 2.0L...
Put new batterys on 2002 f250 diesel now my power door locks dont work and my open door light on dash stays on
as for your door locks, your key fob may have been misprogrammed when you removed the battery. refer to owners manual to reset your locking options on your key fobs. as fot the door open light, try spraying a silicone based product into the inside door lock mechanisms. silicone spray is much better than wd 40.
Feb 25, 2012 | 2002 Ford E250
2002 Explorer V6. Power door locks have stopped working.
Mine just started doing the exact same thing tonight. I disconnected the battery to change a DPFE sensor and when I reconnected I had this problem. I also have auto headlamps and they are not working either. I don't know what is wrong, I checked all the fuses also and everything looks good. I wonder if it is a relay??? I will make sure I respond to you if I find a solution.
Mar 28, 2010 | 2002 Ford Explorer
Program a new fob to my 2002 f150 supercrew lariat 5.4L remote lock/start system
if it is a ford remote or ford factory alarm remote cycle the key from off to run(usually 8 times) untill you hear door locks activate. at this exact time key needs to be in the on position.touch unlock or lock on all remotes being programmed and make sure door locks respond to remotes. then turn key off ending programming mode.then try your fobs they should work
Nov 06, 2009 | 2002 Ford F150 Regular Cab
Changed engine in 2002 ford explorer alarm system won't let start engine
if its a factory alarm put key in door and lock and unlock drivers door, then try to start,try that. good luck.
Nov 01, 2009 | 2002 Ford Explorer
Viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Jun 14, 2009 | Viper Security and Remote Start System...
Honda CRV 2002 Power Door lock
try testing or replaceing the drivers door lock actuator, reprogram ur key fobs and try unlocking and locking ur doors. as far as the lights and reminder,....it sounds like a seperate problem. but try the door actuator first (drivers side always act up and cause every other actuator to act up... like a bad kid that gets the rukkus started and ruins things for everyone..
Apr 01, 2009 | 2002 Honda CR-V
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
