Question about GE 36 in. Profile JP968 Electric Cooktop
My 36" GE Profile electric ceramic cooktop gets discolored every time I use it, even at temps only medium (or 6 at highest). I have Al Clad cookware. Is this a defect in product?
This cooktop cannot take temps more than medium or it will leave burn marks which are hard to clean off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Check if your cookware is compatible with this ceramic cooktop.
Posted on Jul 10, 2014
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
SOURCE: can't get GE profile cooktop clean
Don't buy one is a good start unless you like to spend a few hours everyday attempting to make it look clean. If you are OC you'll love the cooktop BTW. Crappy engineering and source selection. Include it in the price when you move.
Posted on Oct 19, 2009
  • 4 Answers
SOURCE: i have GE Profile? 36"
unplug it and buy a new one
Posted on Dec 05, 2010
  • 3287 Answers
SOURCE: The unit light (not the hot surface indicator
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Posted on Sep 16, 2011
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Replace fan switch on ge cooktop profile
I agree completely with imaginus2000. GE Profile is junk. Came with the house we bought so had no choice there. As soon as it craps out it will be sent where it belongs. The scrap yard!
May 26, 2012 | GE Profile 36" Electric Induction Cooktop...
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
The Halogen burner on my 36" GE profile cooktop does not work
Sorry to read about your problem, I hope this helps you out.
either the element is burned out or the control relay is defective,
I suggest you call a service company
If you live in the Denver area i can help you...
Dec 19, 2010 | GE 36 in. Profile JP969SHSS Electric...
Has anyone figured out a way to remove the dark stains that you can't get out on the ceramic top with the recommended cleaners?
no any kind of chemical u can use to remove the stain,coz its normal for ceramic hob cooker coz of pots n pons every time u use.
Jul 02, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Ge profile ceramic electric cooktop
Oct 26, 2007 | GE Profile JGP636 Gas Cooktop
GE 36 in. Profile JP968 Electric Cooktop Logo
139 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
