Question about Radio Communications
What is the best scanner to receive local police reports
Any specific brand or channel access?
  • 31 Answers
The all depends on what the police are using in your area. If the police are on a simplex frequency or a local repeater, just about any scanner will do. If you are in an area with P25 digital trunking, you are going to need a more expensive scanner such as the Uniden BC396XT or the brand new Uniden BCD436HP.
Uniden BCD436HP HomePatrol Series Digital Handheld Scanner
Posted on Jun 22, 2014
sir fixalot
  • 146 Answers
SOURCE: police frequencies codes
Here is a great link for you guys out in scanner land:
http://www.radioreference.com/apps/db/
Posted on Jan 04, 2008
  • 905 Answers
SOURCE: police scanner wont pick up police frequencies
do you still have a warranty? because it is going to need repair
you can try to leave it unplugged for a while , but otherwise its going to need repair
Posted on Nov 29, 2008
SOURCE: police and emergency scanner codes for lewis county?
You can find a short list of police, and EMS freq. CLICK HERE
Posted on Jan 05, 2009
  • 160 Answers
SOURCE: i need local police/ fire codes where do i get them?
http://www.radioreference.com/apps/db/?stid=30
Posted on Jul 07, 2009
BillB-SA
  • 2761 Answers
SOURCE: I need to reprogram my Realistic Pro-2023 police
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Posted on Feb 21, 2010
I can't get local police on my uniden bc345crs
That's because many police departments use a baud rate (similar to old fax modems) to decrypt the voice and then put it back together again with the right encryption key
Nov 28, 2013 | Uniden Bearcat BC345CRS Police Scanner
I have a bc350c 800 mhz and cant get nothing but static how to i get the police channels to work
Try tuning known frequencies, such as the NOAA weather channels, to verify the working condition of your scanner. If it picks them up, you don't have your local police system/frequencies programmed properly. If there's no reception, even on NOAA, you have an antenna or receiver problem that may need professional attention.
In case you need it, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Apr 27, 2010 | Uniden BC796D Base Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
3 - 4.
transmissions.
stops.
features.
activity.
1. Press MANUAL.
Bill B
Feb 21, 2010 | Radio Communications
Have a programable police/fire scanner and no local codes?
Hello there:
here is a couple of links that will get you to where you can find them
  1. Police Scanner Frequencies & Scanner Frequency Resourcessafe.gif Police scanner frequency page where you can find scanner frequency resources from across the net US including free and commercial databases and listings.
    www.police-scanner.info/police-scanner-frequencies.htm - Cached - Similar
  2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff!.avgnotice { width: 320px; font-size: 7px; line-height: 7px;}.avgimage { height: 7px;}.avgborder { border-color: #00A120; border-style: solid; border-width: 0 3px; font-family: Arial, Helvetica, sans-serif; font-size: 10px; line-height: 13px;}.avgsep { border-color: #C0A8A6 #C0A8A6 #FFFCF7 #FFFCF7; border-style: solid; border-width: 1px 0; font-size: 0px; line-height: 0px;}.avgtop { text-align: center; background: #F4FBF4 repeat-x url(chrome://searchshield/content/background_top_green.gif); padding: 0 5px; height: 30px;}.avgmiddle { background: #C3E5CA repeat-x url(chrome://searchshield/content/background_middle_green.gif); padding: 5px 10px; word-wrap: break-word; overflow: hidden;}.avgbottom { background: #00A120; padding: 10px 5px 0 10px; border: 1px solid #00A120;}.avgbottom td { font-size: 10px; color: #ffffff;}a.avgbutton { color: #0000ff; display: block; padding-top: 3px; width: 69px; height: 20px; text-align: center; background: no-repeat url(chrome://searchshield/content/click_here_green.gif);}.avgtitle { color: #00A120; font-size: 11px; font-weight: bold; margin-bottom: 8px;}.avgnote { font-size: 9px; font-weight: bold; padding-top: 5px;} --> Safe: This page contains no active threats. Explanation:
    It is safe to proceed to this page.
    Domain:
    IP Address: 207.217.125.50
    Owner:
       Name:
       Address:
       Country Code:
    Scanned on: 10/13/09 20:44:43
    (1.08 seconds to scan this page)
    Ratings are provided by AVG. Site owners please contact AVG Technologies for questions. Keep up to date with the latest AVG news and updates. Visit the AVG website.
    click here Get our most complete protection against online threats. Get AVG Internet Security today. Find out how. click here ')" id="XPLSS_389644331U1" src="chrome://searchshield/content/safe.gif" border="0" hspace="5" /> Find everything about police scanners; general police scanner info, police scanner frequencies, live police scanner feeds, police scanner websites & more ...
    www.police-scanner.info/ - Similar
  3. you can also go to police scanner live to get some local codes ok
  4. I really hope that this is verry helpfull
  5. best regards michael
Oct 14, 2009 | Uniden Radio Communications
Locking in to my local police dept
they should have sold you the book with all the codes for law enforcment agencies so you can program all the codes u want to hear
Feb 22, 2009 | Radio Shack Pro-95 Handheld Scanner
Pro-94 will not recieve
I would make sure you have
the new frequency # put in scanner
GOOGLE free new scanner frequency #
put in your town and city.
Jan 29, 2009 | Radio Shack Pro-94 Scanner
I'm tring to find codes for a police scanner for henderson,ky.
RadioReference.com is the world's largest radio communications reference website, featuring a complete frequency database, trunked radio system information, FCC License assignments and callsign maps, 10-Code Lists, agency maps, files, downloads, links, and detailed agency information for most public safety, military, and local government communications.
Best of all, registration and access to all the data is free, however some special reporting features and downloads are only available to Premium Subscribers of the site.
that should solve your problem
Jan 11, 2009 | Radio Shack Pro-95 Handheld Scanner
Radio Communications Logo
156 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
