Question about Yamaha RX-671 Audio video AV Receiver for Home Theater RXV671
Selecting bi-amp mode
I have connected bose am 10 (5.1 speaker) system to the rxv671. recently i coupled boston cube 2 speakers to for additional surrounding. here when i put to bi-amp mode, it gives crispy sounds rather that 7CH mode. please let me is it okay with the system.
SOURCE: no sound from Zone 2/3 speakers
had the same issue ...only resolved it by adding the analougue inputs for other components as zone 2 didnt seem to work with optical inputs i had for main speakers
Posted on Jul 05, 2008
SOURCE: no zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Posted on Mar 08, 2009
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
On the connection for my Boston Vr2 Floor Speakers there are 4 connections which are connected vertically with a brass plate which is approx 1/2 " wide. I have lost one and the speaker does not seem
You can use a piece of speaker wire to replace the missing bar. those speakers are designed to be used with the bars in place for normal use. they can be removed if you are bi-amp/bi-wireing them.
Jan 14, 2013 | Boston Acoustics Audio Players & Recorders
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Nov 26, 2008 | Bose Lifestyle 38 System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Yamaha RX-671 Audio video AV Receiver for Home Theater RXV671 Logo
44 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
