Question about SprayTECH 0277938 - Turbine Assy / CapSpray CS-9100
My spray gun is spitting the paint
I have cleaned it well and changed the packing but but it keeps spitting!
Hey everyone. I have a 09 r1 that keeps spitting out coolant from the reserve tank down on the left side of the bike. Ive already changed the coolant but it still spits out coolant. Thermastat prob?
If your coolest is coming out of the over flow bottle lid check your breather line for a blockage as the breather lines do need cleaning
Feb 24, 2015 | Yamaha Motorcycles
Spitting
most paint spray guns require the paint to be thinned this may be the cause of the spitting
Apr 15, 2014 | DeVilbiss Jga-510 Paint Gun Sprayer Item...
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
Paint gun not shooting correctly
Seeing how you have really stated what the problem is (spitting, clogged, won't shut off, fan pattern wont adjust Etc) and there could be several different things wrong- lets go over some basic spraying A B C'S- always strain the paint through a strainer bag or cone this will remove any debri that might clog the tip, *THINNING when you spray or atomize paint it should always be thinned it will actually cover much better if you thin it with the appropriate solvent water for latex thinner for oil base you want to stay in the 15% range alittle bit more on hot days. The shape of the spray that comes out of the tip is called "fan pattern" or "tip fan" "fan size" you can adjust the fan pattern from 9:00 - 3::00 or sideways to straight up and down or to a small circle this is done by moving the "tip housing retainer" keep a piece of cardboard to practice and see. IMPORTANT:When you have finished spraying you need to clean the entire gun by running the right solvent through the gun untill nothing but clean solvent is coming out dissemble the gun remove and clean needle and needle housing this is not very complicated and is paramount to maintaining any spray equipment for sure the gun....
Perry Tradesman
Dec 29, 2013 | GRACO INC 3900 Handheld Paint Sprayer...
Honda Shadow, spits and sputters
Put a spike air filter on my 06 honda shadow spirit 750cc and now it spits and sputters won't go past 35 with out spitting and sputtering
Jul 01, 2013 | Motorcycles
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
I bought the vcr quasar vhq 940 used and it keeps spitting the tape back out. How do I fix it?
It means the unit has either a bad belt or belts or a bad drive wheel--if the tape goes in the unit opens the cassette and feeds the tape out--if broken or loose belt it will not make it fully out against the video heads and will spit tape out.
Used to be by model number belt packs with a idler included to replace all at one time.
Use or hours does not matter as if the unit sits a long time or is rarely used the belts and idler (rubber) will degrade and cause problems.
Apr 10, 2012 | Televison & Video
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
SprayTECH 0277938 - Turbine Assy / CapSpray CS-9100 Logo
60 people viewed this question
Top SprayTECH Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a SprayTECH Air Tool and Compressor Expert? Answer questions, earn points and help others
