Question about Yamaha HTR-5063 Receiver
How to pass video through the receiver
Can I pass through video from my laptop (HDMI) to my receiver (Yamaha HTR-5063) through RCA video (from "monitor out") to a projector (only has RCA input)? I assume the answer is either: A) buy a HDMI to 3-RCA cable or more likely B) buy an HDMI to RCA mini converter box.
  • 66 Answers
The cable hdmi to rca does not work it is a scam. b option will work but cost a lot of money. if your receiver has an rca out that should work to your projector not sure about the in and output mode to do that from your receiver
Posted on Apr 19, 2014
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
DickCanFixIt
  • 948 Answers
SOURCE: I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Posted on Dec 29, 2008
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
How do reset my HTR 5063 Yamaha receiver to my Sony Bluray video component and also my Direct TV
Just what kind of problem are you having, and what connections are you using presently?
Dec 17, 2014 | Yamaha HTR-5063 Receiver
Woke up to my HTR-5063 sounding like I was in a wind tunnel. All inputs sound like a microphone out in a wind storm I upgraded the firmware to see if this would solve the problem but no go Is this...
This is toast. A bad audio amplifier circuit. You're gonna need to take this to an electronics repair shop, because these are not easy to fix yourself.
Jun 16, 2011 | Yamaha HTR-5063 Receiver
Should I be using a separate optical cable when connecting a Blu ray player with and HDMI ?
hi,
There is no need of connecting optical cable. the only thing you have to do is set the digital input assignment as HDMI (means setting the digital input source HDMI) in your av receiver. Also remember one thing, set the digital output setup of ur blue ray player also as HDMI. then only u will get audio through HDMI
if you need any more assistance fell free to contact me through fixya.
ok
Jan 26, 2011 | Yamaha HTR-5063 Receiver
I have a Yamaha HTR-5440 receiver and I want to connect it to my Directtv Plus HD DVR satilite receiver what do I need
If your yamaha receiver has Hdmi upconversion and HDMI pass through you should only need an HDMI cable. One from the directv receiver to the Yamaha Receiver and another from the yamaha receiver to the tv. If it does not have HDMI then you'll need component video cables and 1 optical cable.
Oct 23, 2009 | Audio Players & Recorders
Hdmi in but no analog out
the guy was wrong. the analog and digital portions of the receiver are totally separate.
according to Yamaha:
"Be sure to connect your video components in the same way you connect your video monitor to this unit. For example, if you connect your video monitor to this unit using an HDMI or COMPONENT VIDEO connection, connect your video components to this unit using
the HDMI or COMPONENT VIDEO connection."
sorry bud:-(
Feb 28, 2009 | Yamaha HTR-6130 Receiver
Yamaha HTR-5063 Receiver Logo
116 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
