Question about Lime Pro Equipment Exercise & Fitness
All wires were damaged
The problem with the unit is that i can't replaced all the because it's all gone. and i think rats were the culprit. if only there were wires left i can easily trace their color and fix it but rats ate it all all the way from end to end.
burzerko
  • 254 Answers
SOURCE: Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Posted on Jun 04, 2008
  • 18 Answers
SOURCE: mice ate transducer wire
cut the wire and re connect with crimp connectors and then seal withe heat shring tubing and a heat gun (put the tubing in first) or you could solder the ends together and heat shrink tubing over the individual wires. So long as you have a good water tight connection ther should be no adverse affects to your equipment.
Posted on Sep 19, 2008
  • 4340 Answers
SOURCE: Rats ate my vacuum lines on my v-10 1999 ford
The correct diagram should be located under the hood.
Posted on Sep 07, 2009
ZJLimited
  • 17970 Answers
SOURCE: rats ate my wires I need complete wire diagram for 2000 ford f250
Review in autozone.com (free register), there you can find 31 Wiring Diagrams about F250.
Good luck (remember rated this help).
Posted on Oct 15, 2009
Testimonial: "good job but for some reason it does not show me for the year that i need"
  • 342 Answers
SOURCE: i have a coleman powermate generator that my dog
look for a manual with diagrams
Posted on Apr 04, 2010
Subaru 2008 forester has power to running lights but the engine will not start or turn over ?
No. Brake light has nothing to do with that. You probably have some more damaged wires somewhere. Rats mice and squirrels can do major damage to wiring harnesses and often chew them in multiple places
Jul 06, 2016 | Subaru Forester Cars & Trucks
Hello, I have a little giant #508158, pump is approx. 2 years old used about 4 times to drain a residential pool that is in-op @ the moment, however the pump has stopped working, the GFCI does "not" trip,...
To be precautious, if the damage to the wire is near to the appliance you might be lucky enough to savage it as it is hard to come by. Cut the wire 2 -3 inches away from the damage and hang to drain dry for 2 days or so if there is any sign of water ingress. leave the damaged wire in situ until you are ready to remake a connection with the salvaged piece, salvage any water tight shroud on the wire into the pump or replace it with new.
When you open the electric box on the pump it would pay you to test the pump motor with a mega, to see if the motor is down if it is need I say any more.
When you have finished the repair or what ever, it might be an idea to store the pump , either repaired or replaced inside a metal box and put some rat poison baited traps around, also leave a couple of Asprins out for the rat in case it get guts ache.
Mar 11, 2014 | Plumbing
The emission light came on our 2010 Honda Odyssey with 2500 miles. Brought in to dealer who told us a RAT!?! chewed the line so the repair would not be under warranty. I smell a rat & it's not the...
Hi:
Unfortunately, there have been lots of cases of rodents chewing on car wiring. In the last five years or so, wire manufacturers have used soy beans as an ingredient in the insulation coating on automobile wiring,and it seems it is tasty to our small friends. Depending on where you park your car , will make you succeptible to it happening again. The Mom of a friend of mine had $1000 worth of damage to her car wiring, as some chipmunks had a field day with her newer car. She ended up placing some moth balls around where her car was parked, to keep the critters away. If you have wildlife near your car, look out!
Feb 09, 2010 | 2009 Honda Odyssey
Wiring was damaged by the rat. could not identify coded wir
google the manufacturer and ask for Maintenance Manual
Oct 23, 2009 | Washing Machines
Under warranty
I have seen the damage that one squirrel has done on a Dodge van. Unfortunately all of the injector wires needed to be respliced. It happens more often than you think. I also knew of a rat that chewed through a serpentine belt on a 5.0 liter Mustang. The owner started the car and chewed the heck out of that rat. True story. What a mess he made.
Apr 23, 2009 | 2007 Land Rover LR3 V6
MissFire?
i think you might have a mouse living in your engine compartment
but i would look at a mouse dead inside your muffler since this is the warmest place the cuts off the cars way of breathing
when you come to a stop the dead mouse moves inside muffler and creates a blockage just enough to almost smother vehicle rats find muffler pipes warm area to live in
i would also change the oxygen sensor out too
since you mentioned rats i would gothrew whole vehicle in detail and look for chewed frayed wires windshield wiper motors things of this nature they may have chewed threw a relay and you wouldnt know once you have rats they can do lots of damage to a vehicle
also if vehicle sat for long time i would check the tank for debry and change the sending units filter out for better performance along with vehicles fuel filters
fuel injector relay can also be bad giving you the chug
bad coil
build of gunk in the throttle body houseing
air filter clog or not enough air
these are things i can think off the top of my head since im not there in person to see vehicle
i hope this had helped you in some remedy
Jun 13, 2008 | 2005 Dodge Neon
2005 Dodge Neon SXT misfire??
bad coil
Jun 12, 2008 | 2005 Dodge Neon
Cutting of thermistor wire by rat
If you have enough loose end on the wire you can make a splice and solder the point. Insulated it well with electrical tape. The alternate is to replace the thermistor which and more than likely be ordered by model number and serial number of your unit.
May 27, 2008 | LG Electronic Window Air Conditioner
Ge profile 2004
First, the unit should be installed so that the floor is level and even. If not, the door cannot close properly because the cabinet will be distorted. There are some adjustments which can be made according the the manual. Make them. Second, look at the door itself. If the gasket is distorted or damaged by the rodent or it is dried out or ripped, you'll have to replace what's damaged. Check that the hinges are properly installed and tight. The door should swing freely. There is generally nothing inside the door which should interfere with it closing properly however, if you've overloaded the bins, it could interfere.
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Exercise & Fitness Logo
24 people viewed this question
Top Lime Pro Equipment Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Lime Pro Equipment Exercise and Fitnes Expert? Answer questions, earn points and help others
