Cable tv I can not get my cable tv install in the back of my tv the conector is diferente Samsung tv LE23R88BD,HELP
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
If its not coax..it must be hdmi..if not you can use rgb connectors..or component..what is the tv input?..and what is the tv input?
Posted on May 12, 2014
  • Michael Harrier May 12, 2014
    if its not coax..it must be hdmi..if not you can use rgb connectors..or component..what is the cable input?..and what is the tv input?
I have a samsung tv model le23r88bd i want set up cable but the tv have a diferent cable conector that i need it a adaptor?
Need more info can u post a picture of the back of the tv and the type of cable your trying to connect?
Mar 25, 2014 | Televison & Video
I've lost use of the red button on my Samsung LE23R88BD. No longer have instruction manual, so how do I do it ? Thank you
UK SAMSUNG LE23R88BD
You can download a manual from;
http://www.nodevice.com/user_manual/samsung/tv/le23r88bd.html
Scroll down to the download part and enter the code to start the download.
If you need an ADOBE reader you can get one from www.getADOBE.com
Apr 17, 2011 | Samsung Televison & Video
Hi we had to move & unplugged the DVD/R & I dont know where to plug the cords back into the back of the player or the TV. I can get video ok but no sound. Thanks in advance.
unplug the red and white cables from dvd , next, plug only white cable in the white conector of the dvd and listen the audio, if is not ok, try in another white conector of the same dvd until you obtain good sound, do the same with the red cable.
Apr 10, 2010 | Samsung DVD-R130 DVD Recorder
Mapa
Necesitas especificar el tipo, la marca, del tablero, etc. Sin eso es muy difícil ayudarte
100%.
Sin embargo, si tienes el tablero a mano, habiendo removido sus componentes, usando una linterna y una lupa, es muy probable que puedas leer, estampados en el tablero, las
indicaciones de dónde van los diferentes componentes. Ejemplo: Spkr->Parlante; Pwr LED->Indicador de Energia para el exterior de la caja de tu PC; etc.
Los demás conectores tienen su forma y tamaño fabricados de modo tal que sea imposible insertar un componente de la manera equivocada, pues saben tener un agujero faltante o un corte en su marco para evitar la inserción incorrecta de un conector.
Los soquetes para los discos duros, 2 de tipo IDE y 2 para SATA, comunes en PCs modernos, funcionan no importa dónde se conecten, a menos que uses dos de cada clase, lo cual podría necesitar de quitar un "jumper" en uno de ellos.
En cuanto a los puertos USB, es algo más complicado porque generalmente dos de ellos son compartidos. O usas estos dos en la parte posterior, o al frente de la caja del PC, pero no simultáneamente en ambos lados. ¿No será esta la razón por la que estás dudando y piensas que necesitas verificar estas conecciones?
De los 6 puertos de USB, sólo 4 están activos 100% del tiempo. Los otros 2 son compartidos.
Espero esto haya sido útil.
¡Buena suerte!
Jul 27, 2009 | Computers & Internet
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Line in promlem
it been seem that you are not clear with facts to help you in proper way.
anyway i try to explain you general way.
first a internal tv card have two sound conectors, one in one out.
you must take with apropriate cable sound from output conector in your tv tuner card and the other extreme put it in line in (blue) conector in your Mb system sound card(there are last three one green one red and one blue ). now you have maket this go to program that control sound card and choose the right entry for you line in (blue conector). after that if sound isnt comming you must go to the tv settings to put the right output for your sound, and specify even is in rear or front side (in your case in rear side).prove this steps and write me back again is that helpful, or part of it so i can help you again from point you failed .
Apr 05, 2009 | Intel DG31PR Motherboard
I can not put my lcd in hdmi chanel dont have manual
hdmi refers to a conector. The cable box or DVD has a hdmi conector and is needed a cable with a hdmi conector build-in who attaches to the hdmi tv conector. HDMI is a known interface in between the sets that susutitute the RCA conector.
Feb 13, 2009 | Pioneer PureVision PDP-435XDE 43 in....
"No Connection"... My first attempt with HDMI SUUUUCKS- HELP
The connector board inside the tv is the one has circuit traces already broken. there is nothing outside the tv can be done. The HDMI conector is high end technology solder. finally the solution is to replace the conector board inside the tv.
Jan 02, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
How do I connect my dvd recorder xbr716 to the television?
Tiene tu televisor entradas de audio y video,si las tiene no hay mucha dificultad para conectarlo,el aparato trae unos cables rca con diferente color rojo blanco y amarillo, el rojo y el blanco los vas a poner en las salidas (outputs) de audio del dvd las que son del mismo color,el conector amarillo lo vas a poner donde dice video output, y en la tv los conectas donde dice inputs en el mismo color del conector.Pones tu tv para entrada de video y ya esta.
Mar 23, 2008 | Zenith XBR716
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
