Question about Nilfisk Vacuums
Dust bag ripped, now wont turn on
The dust bag was too full and when I checked it it had ripped now when I plug it in and turn it on it wont start
Dust bag not the problem so take into guarantee vacuum and sewing center and they will clean it out completely and get it fixed and running like new at as little cost as posible
Posted on Mar 26, 2014
2 Suggested Answers
SOURCE: Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Posted on Jan 08, 2008
I have the porter cable 10 gallon tool trigger drywall vac why is it that the bags keep braking. Have had it for years and it's only been about the last two years they rip open way before they are half...
Need some more information, are you vacuuming dry wall dust or wet dust or saw dust ? The reason I ask is sometime their are "upgrades" available for the newer models of vacs you may not be aware of, when I worked at the Big Box H D tool rental center the vac we rented out used a water filtration set up instead of bags U might wont to check newer model for any changes, like you ,I had Craftsman for over 15 yrs. and when it died the replacement vac had a new mod for the filter that I always thought was needed. Good luck , Bret
Sep 28, 2014 | Porter Cable 7812 Wet/Dry Vacuum
Riccar vacume lite for bag is on when bag is not full
sometimes that can happen if the pores in the bag are clogged, as might happen if you have been vacuuming very fine dust like wallboard dust. this means that the bag might be functionally full, even though it still appears un-full. also, check the hose for a clog, because that can also give a false indication light.
Jul 10, 2014 | Riccar 8955 Upright Vacuum
How do you read the "full bag indicator" on a Meile S7260?
typically if your vacuum is loosing performance it is time to replace the bag depends on how fine of dust some really fine dust will clog the pores at a 1/4 full
Apr 14, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
I have a Bissell DigiPro canister vacuum and it has no suction. It is only 4 months old. What would the problem be?
Probably a clog in the hose. Disconnect the hose at both ends. Drop a coin in one end and allow it to fall through and out the other end. If it doesn't, the hose is blocked. Plug the end of the hose into the blower of the vacuum and turn it on. Make sure the other end of the hose is in a plastic bag. This should clear the clog.
Also, check the power nozzle behind the brush. Something may have gotten caught in the elbow near where the wand plugs in.
A full bag will also cause this, or if there's a lot of fine dust in your area, clogged pores in the bag will act the same as a full bag.
Jan 20, 2011 | Bissell 6900 DigiPro Bagged Canister...
While vacuuming the red light for the bag of the vacuum came on and the vacuum stopped. The bag was no where near full so I replaced it with a new bag - same problem. It vaccumes for a minute or then stops...
I'm assuming this is the Epic 6500 or similar model.
Detach the hose, turn vacuum on. If it runs, place palm of hand against inport hole. If it shuts off the problem is with either the control valve setting or the control valve assembly itself.
For cvs, turn dial on top of vacuum all the way to the largest dot, and try above test again. If that doesn't work, then it's the CVA. It needs to be cleaned or replaced, which is an in shop job. Fro repair, take it to the nearest Aerus Electrolux store. I recommend a full clean and service to remove any dust/dirt from the motor, fan assembly, and other internal parts.
Another problem, which relates to the dial setting, is that fine dust will quickly clog the pores of the bag, resulting in the machine "thinking" the bag is full. Turning the dial to the proper setting helps get the bag fuller. The middle setting is the normal setting, and is for areas without fine dust and sand.
Dec 05, 2010 | Electrolux Vacuums
Why does my shop vac back fire dust when I vacuum?
HI,
A vac bag will disperse Dust. If there is a tear Or rip In The Bag.
Try replacing or emptying the existing Bag. ensuring That Any Clips Are Intact.
Mike @ Compurepair.
Oct 16, 2009 | Vacuums
Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Just powered itself off
It will shut off if your bag is full. If you are cleaning up fine dust, it will give a false bag full indication. Take the bag out and carefully, shake it down to get the dust out of the filter layers inside. This will let more air flow through the sensor.
Nov 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
41 people viewed this question
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
