Question about Drive Medical Winnie Walker, Mimi Lite Push Brake Rollator
How to get the front drum off a 63 dodge dart
Trying to replace and adjust front and rear brakes and drums on a 63 dodge dart
Adjust parking cable 99 dodge dakota -drum brakes
Unless you have replaced the cable, it should never need to be adjusted. If you can reach under the vehicle, and when wiggling the parking brake cable, if it is taut (not sagging), then it is probably adjusted properly. What usually causes the parking brake cable to appear mis-adjusted (the parking brake won't hold the vehicle), is that the self-adjusters in the rear drum brakes are not working properly. This is bad because it means that you are not getting proper braking from the rear brakes as well as having the parking brake issue. This can cause premature wear to the front disc brake pads/rotors and affect braking power and control under certain stopping conditions. Front disc brakes work so well that many people never realize that their rear brakes aren't doing their fair share. The purpose of the self-adjusters in the drum brakes is to keep the rear brake shoes at a consistent distance from the drum's inner surface as the shoe lining wears down. If the adjuster works correctly, the parking brake will always stay in adjustment. You CAN adjust the parking brake cable, but if the problem is actually with the self-adjuster, you are masking the real problem, and later on when you need to replace the rear brake shoes, you will find it impossible to put the drum back on over the shoes as the parking brake will have the shoes pushed out too far. Have a mechanic check out the self-adjuster mechanism. It is always a good idea whenever you replace the rear brake shoes to replace all the rear brake hardware as well. You don't replace rear brakes nearly as often as the front ones, and the cost of the hardware is minimal in relation to the satisfaction of knowing that non-corroded parts will work better and provide longer service than the older, gummed-up and rusted hardware that is currently installed.
Sep 11, 2014 | Dodge Dakota Cars & Trucks
How do you change rear brake drum on 2002 dodge ram 3500 dually
you have to get under truck look for access hole at backing plate you need brake adjusting tool to turn adjusting star wheel until drum brakes away from brake drum so you can remove the brake drum.you need tools to remove rear wheel from drums you need a large breaker bar and large hammer and a large socket remove spindle nut.
May 18, 2013 | 2002 Dodge Ram 3500 Truck
Squeeling rear brakes - Out of ideas.
re move drum and shoes replace drum and rotate drum slowly to see where the drum catches then remove drum and tap back plate with hammer then try again untill its not catching ie both sides
Aug 18, 2012 | 1997 Dodge Stratus
Picture of 1974 dodge dart rear drum brakes
For drum brake related problem,i suggest you to go through this help links.Clickj the link below for troubleshooting procedure:-----How to service Drum brakes?http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html--------What type of problems usually noticed on Drum brakes?http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html---------How to test Drum Brakes?http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
---------How to inspect brake drums?http://repairhelpcenter.blogspot.in/2012/02/how-to-inspect-brake-drums.html
---------This will help.Thanks.
Jan 24, 2012 | Dart 1970 Dodge Dart Swinger 340 1/18 B5...
Which is the primary shoe
Short shoe on the front long shoe on the back. Drum style brakes are self energizing. When the wheel cylinder pushes the shoes out, the front shoe tries to spin with the drum, which pushes on the adjuster, pressing on the rear shoe. So the rear shoe is pushed into the drum by the wheel cyl, and the front shoe.
Jan 16, 2011 | 1998 Dodge Ram 3500 2WD
2000 dodge status non and I have brake pressure at right rear and left get nothing on other two have replaced master power booster lines wheel cyls callers and still no brakes have followed bleeding...
When you do a brake job with drums. You have to adjust the brakes by hand the first time. It doesn't hurt to put a little lude on the slack adjusters. Also if your reusing the brake drums, you need to grind or file the lip off the edge of the drum. this will throw off the adjustment.
Dec 05, 2010 | 2000 Dodge Stratus
My '83 dodge ram van goes in reverse fine,but when i try to go forward, the R rear wheel spins, seems the L rear is jamming?? is this a diff or brake issue?
sometimes the emergency brake will stick even after it is released. Most drum brakes will still let it go backwards but not forward. I would pull the rear drums and check. If e/brake is stuck removing the left drum will be difficult. If so then you will have to manually adjust the brakes until drum loosens up. good luck
Jan 18, 2010 | 1983 Dodge Pickup
When I apply the brakes on my '02Dakota only the forward brake shoe moves against the drum. Have replaced wheel cylinder but makes no difference. Both shoes move when I loosen adjuster cable. Have this...
you mean parking brake cable? loosen parking brake cables put drums on , and adjust shoes till they lightly drag, now apply brakes a few times and check the adjustment again, if all ok, now adjust park brake cables, you want to adjust so park pedal goes 5-8 clicks till the wheels are "locked up" and the wheels spin free with the park brake off
Oct 18, 2009 | 1992 Dodge Dakota
I replaced rear drum pads on 1998 dodge durango. They are SMOKIN
did u turn drums? if so did u have to force drums back on? if u did that was a no no something is not right inside that u over looked,,if the drums where loose when u where finished with brakes untill u aplied them then u have a colasped brake hose,replace
Jul 05, 2009 | Dodge Dakota Cars & Trucks
1999 Dodge Ram 1500 conversion van rear brake hammering
Are the brake shoes on right, there are two size shoes, One shoe has a longer brake lining then the other. The short brake lining is towards the front of the van and the longer brake lining is towards the rear. The rear brakes also may need to be adjusted, you can do that by going in revers in a empty parking lot and push the brakes as hard as you can to stop the van. Don't give your self a whip lash, just push down gradually and as far to the floor you can about 7 to 10 times. The self adjusters should adjust the brake on both sides, try this first before you take the brakes apart again. It may just need a adjustment and after that check the brake fluid in the master cylinder. Good luck and hope this helps. Keep me posted, be glad to help
Jun 20, 2009 | 1999 Dodge Ram
Drive Medical Winnie Walker, Mimi Lite Push Brake Rollator Logo
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
