Question about Tricity Bendix TMG209 Microwave Oven
Grill gets hot when just using microwave?
When using the microwave only, why does the grill element get hot also? The grill symbol does not show, only the microwave and micro power symbols.
  • Brian Wright
    Brian Wright Mar 27, 2014
    When I operate the microwave only function, the grill gets hot. The only functions that show are the one for the microwave and the one for the microwave power. Tricity TMG209
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
GRILL COMING ON WHEN USING CONVECTION COOKING
This is correct. The grill element is the heater for the convection system.
Mar 08, 2011 | LG Microwave Ovens
What is the minimum distance from the top of oven to the bottom of microwave
It depends greatly on the ventilation but if you use 20" above the hob, as a good starting point. If you have extractor fans, maybe less. Don't forget the grill gets hot on top of the oven but there should be at least 10" clearence between the grill top and the microwave base, more if it is gas!
Dec 21, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Grill element stopped working.
I had the same. Dismantle the oven and see at the back side the connection wires for the heat element. Mostly one of the connectors is faulty. I fixed it that way.
Jul 29, 2009 | AEG MCC663 Microwave Oven
Tricity Bendix TMG209 Microwave Oven Logo
15 people viewed this question
Top Tricity Bendix Microwave Ovens Experts
William Miller
William Miller
Are you a Tricity Bendix Microwave Oven Expert? Answer questions, earn points and help others
