Question about Clarion XMD3
XMD3 RCA outputs
Trying to figure out which RCA outputs are which (Red, Black and White). Can somebody help me?
I have a sony str-DE695 and I am trying to hook up my speakers/record player to it. The record player has an RCA chord with one white and one black end. The speakers has the same chord but with one red and...
the inputs should be marked phone (if on the reciever the colors are red/white and the colors of the rca ends are black white put the black plug in the red and white plug into the white input..if the stereo doesn't have rca speaker output ports you'll need to cut off the speaker rca's and strip the wires bare then comnnect usually copper (red) silver (white) or pos (silver) neg (copper.
Sep 26, 2012 | Sony STR-DE695 Digital Audio/Video Control...
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
I have a turntable with a white and a red male RCA output cable. I am trying to hook it up to a Marathon DJ-1000 amp which has two TRS input channels - Channel 1 and Channel 2. Should I buy a twin female...
If I understand you correctly each channel has a single input in the amp, then yes! white goes into channel 1 and the red plug goes to channel 2 this way your signal will be stronger which translates into louder sound.
Jan 25, 2011 | RCA Audio Players & Recorders
Im trying to find an audio output for my tv or a headphone jack but with so many things on the tv i cant find it.. help
There should be two RCA jacks on the back for left and right audio outputs, white and red respectively, if it has stereo out. Connect these outputs to a stereo receiver or amplifier into an auxiliary port or TV audio input via a red and white RCA cable.
Nov 10, 2010 | Televison & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
Jun 20, 2009 | Clarion XMD3
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
WIRES!!!!
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Oct 29, 2007 | Clarion DB255 CD Player
Clarion XMD3 Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
