Question about Insignia IS-LCDTV32 32 in. Television
Cant conect pc to tv
It will display start up but then says no signal
Cant add my tv display
On my older dell latitude when using a vga cable to the tv you would go to computer's control panel and then "display" then settings. You should be able to click on the #2 monitor then apply the changes.
Jun 20, 2012 | Dell Latitude 2100 (blcwwfp) PC Notebook
How to conect recever for tv tuner card
Check signal strength from receiver(set-top box)? Or call cable company?
Feb 09, 2012 | Televison & Video
How i can connect my samsung netbook N210 with panasonic TH42PA20 tv by vga cable
if notebook got vga out and tv got vga is verry simply, conect them and after select tv as your secondary display
cole primary display to the seconday
start tv and go to the imput menu, select pc
and will be ok
just 1 problem the clarity of vga canot be compared whit hdmi conection
best regards
Sep 22, 2011 | Panasonic Televison & Video
When i conect the pc to a tv throught HDMI CORDthier is no signal
are you sure you have the correct drivers to run the HDMI plug on your laptop and also you could check the settings on the laptop to see if you have the correct display settings for it. i hope i have helped
Aug 09, 2010 | HP Pavilion dv5-1000us Notebook PC
Message of Unsupported video signal after attaching laptop to TV.
it sounds like the resolution the laptop is trying to send is not one of the resolutions that the television can display. TVs can display a range of resolutions, so try changing the laptop resolution, either increasing it (make the pixels smaller) or lower the resolution, try a variety of resolutions, one should work.
Jul 11, 2010 | Dell Latitude D420 Notebook
I cant see the menu on the tv, i conected an hdmi cable to the ouput where it says monitor out, and my tv doesnt reconize it.
On page 8 it says, "The on-screen display signals are not outputted from the HDMI MONITOR OUT".
Run a set of cable(s) from the Video- S-Video- or Component Video Out connectors to a compatible input on the TV.
Jun 09, 2010 | Denon AVR-1908
When conecting a pc up no display
Sansui tv's with a PC input are usually 60hz tv's. Try changing the refresh rate on your PC to 60hz. You will need regular computer monitor to make the change on your PC.
May 19, 2010 | Sansui HDLCD-1900 19 in. LCD Television
Conecting my toshiba laptop to an hdtv
u need to start the pc in low resolution mode ... and then check the video resolution .. because this can be a problem with the wrong resolution selected
Mar 24, 2010 | Computers & Internet
Insignia IS-LCDTV32 32 in. Television Logo
27 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
