Question about HP Computers & Internet
I need a picture schedule cables to the motherboard onn tv XQC 15-19 DVC
  • HP Master
  • 3,320 Answers
Not a motherboard
Posted on Mar 25, 2014
Remote codes
0339,0330,0331 are the codes to check with Onn DVCs. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 22, 2014 | Philips Magnavox 20MT133S 20" TV
Plugged onn hdmi cable into tv and laptop and nothiing happens how do i get this to work
You'll need to select the correct display function for the picture to appear on the television. This is typically done by pressing Fn+F5 or Fn+F7, depending on the computer type.
Nov 04, 2011 | Televison & Video
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
Vupoint DVC-ST100VP is connected properly to vcr and to the dvc. SD card is in dvc and I pressed record on the dvc. Once I stopped recording took the SD Card out and played it but there was no picture...
1. the SD card is not formatted for this device
the SD card has to be cleared .
Some SD cards may be defective.
2. Try using the SD card in another device to see if it is operable.
3. check the cables between devices to see if connected correctly.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Jun 14, 2011 | VuPoint DVC-ST100-V-P Video Converter
No Picture
Hi And Welcome to Fixyah,
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
Nov 27, 2009 | Televison & Video
No picture or sound
Shorted hori output and bad FBT flyback transfomer.
Jul 13, 2008 | Sanyo DS31590 31" TV
Computers & Internet Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
