Question about Zoom H4 Handy Recorder
How long does it take to install the firmware to the zoom h4n? Mine is taking forever! And it appears to be frozen on the "verifying data" screen. Anyone have an idea?
Firmware update frozen?
Interrupted update for effects card on Roland vs2480 Now on startup only numeric light light up and machine goes no further
Never interrupt an update especially to flash regardless as what it is because it tends to destroy the firmware. I not very familiar with this unit but manuals etc are on line. My suggestion is to contact the factory and see if you can do a reload of the firmware. Tell them what you did, you are not the first nor the last to do that.
Dec 19, 2014 | Music
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so.
If you are having volume issues, you can adjust them with the following:
Adjusting the volume of individual pads:
-Press Voice.
-Then press Volume.
-Strike the pad you would like to adjust.
-Then use the + and - buttons to adjust the volume of the individual pad.
-To adjust another pad, strike that pad, and repeat step 4 above.
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer!
DM6 Module - Firmware Update [v06]
DM6 Firmware Update Installer for Windows. Updated 04.26.2012
Fix'dYa
Behringer deq2496 displays firmware data not found / what do I do
Go to http://www.behringer.com and update new drivers and firmware. If you lack the Firmware, the system will not open or recognize the device at all. Check with their technical service and tell them to walk you through the process of installing the new firmware.
Dec 19, 2013 | Behringer Ultracurve Pro DEQ2496 Digital...
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
How do i update my Firestudio Preject
  1. Go to http://www.presonus.com/products/Detail.aspx?ProductId=43
  2. Click downloads
  3. Download the software for your OS
  4. Open the downloaded software and follow on screen instructions
The following is OPTIONAL and can potentially DAMAGE or BREAK your device:
  1. If you wish to update your firmware open the universal control software
  2. click settings > check firmware
  3. then follow on screen instructions
Jul 10, 2011 | PreSonus Digimax D8 Digital 8 Mic...
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Jul 06, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Our 32fx mixer has intermittant channel faiures. The symptoms are the channel faders and tones controls stop working, but the audio continues to be routed to the LR outputs. The channel level can the...
Try performing a full firmware re-install, or update if your not already on the current firmware. Click on the "Downloads" tab to access the latest firmware. http://www.peavey.com/products/browse.cfm/action/detail/item/116194/32FX™.cfm
Mar 29, 2010 | Peavey 32fx USB 32 Channel Mixer
Mackie D8B Mixer freezes
Don't know your setup but have you checked out any possible Hum loops? Have you updated any firmware updates? Is your mains input clean (no spikes or very short drop outs of voltage)? Are you near any possible RFI, e.g. Taxi's or CBr's? The list goes on so check out the Mackie forum on the web for more. Good Luck...
Regards,
Frank.
Apr 07, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Zoom H4 Handy Recorder Logo
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
