Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Upright frig/freezer not getting cold, compressor running
Seems to be working fine, except not getting cold
  • 5,660 Answers
1.My first suggestion, is to clean out the compressor area located at the bottom of the refrigerator. Refrigerator unplugged from power. Remove the cardboard panel from the bottom, (Watch the water line), and use a vacuum. I also bring the refrigerator towards an open door, and use compressed air to blow it out, afterward. You'd be surprised how much gunk builds up here, and how cleaning it out will help your fridge tremendously! (Good tip for air conditioners also. Power unplugged, case cover removed. Use a garden hose to flush the fins out. Let it dry, reinstall the cover) 2.Your refrigerator may be low on Freon. This requires a professional to purge the system, and reinstall Freon and lubricant. (Oil)
Posted on Jun 15, 2009
Avanti 308ywt compressor keeps running but frig will not get cold
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
My Frig does not work, Yesterday the frig started to get warm until it is totally warm, I cleaned the coils, compressor runs, fan blows, fan on the coils blows. It seems like the compressor cylces...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Electrolux Refrigerators
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
The frig is not working but the freezer is going strong. Turned up the frig all the way but it does not seem to be doing anything. the tubes in the back of the frig are hot. I don't know anything about...
the tubes behind refrigerator are suppose to be hot.sounds like a defrost problem.turning up thethermostat will only make compressor run longer.cold air is made in freezer then gets moved over to the fridge side.your evaporator is more likely iced up.
Jun 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
305 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
