Question about Olympus FE-170 Digital Camera
Power is on but shows lines. it's not the batteries. Cannot use any function, just shows lines with grey.
    President:
  • 919 Answers
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service. http://olympusamerica.com/cpg_section/cpg_servicerepair.asp Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $61 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 15, 2009
What can cause to not have power on the grey wire going to the fuel pump relay. nd the ecm b fuse to burnt out on a 94chevy astro?I do have power on the wire that's connected to the ecmb it's orng
check for the in line fuse from the battery or you can run a hot wire from the battery to the relay and see if that gives you power to the pump, if so then the in line fuse is blown out.
Aug 01, 2015 | Cars & Trucks
How to elimate the circular moving dots during video playback?
That should just be a buffer. Give the video enough time to load from the source. Generally, there are two lines at the bottom on the playback bar, in the same space. Like, on YouTube for instance, there is the red line that shows how much you've watched, and a grey line that shows how much of the video is loaded. If not enough of the video has loaded, and the red bar catches up to the grey, it will buffer and show the circular moving dots.
Feb 04, 2013 | Computers & Internet
I have found my phone got some problems like automatic switch off during functioning... how do solve it?
it can be battery lose probelum,check battery connector if ok then probelum comes from power ic clean it heat it a little if same then chane p.ic
Aug 05, 2011 | Nokia 5300 Grey Cellular Phone
I LOST THE CONNECTIOS ON PIONNER DEH-2100 HOW I KNOW THE RIGHT CONNECTIONS
Red - Power - Connect to Acc on ignition or battery positive. Connected to Battery the unit will not power down when the ignition is switched off
Yellow - Memory back-up. Connect to battery positive
Black - Connect to vehicle earth or battery negative
Blue/white - Used to power up remote power amplifier or power antenna. Do not draw more than 300mA at 12V from this line
White + White/black - Front left channel
Grey + Grey/Black - Front right channel
Green + Green/black - Rear left channel
Violet + Violet/Black - Rear right channel
Use the wire with the black line in it for negative on any channel.
Do not earth any speaker wires.
RCA output jacks are used to send the output from the unit to an amplifier if you have one and cannot be used to power a speaker.
Dec 29, 2010 | Pioneer DEH-2100 CD Player
NEED TO KNOW THE COLORS FROM THE POWERPLUG
red=power ' black=ground ' yellow = all-time-hot ' blue = power antenna or remote wire (to amp if equiped) orange is for dimmer function i never have luck with this wire working right, suppose to dim head unit with the dash? your purple, green, white and grey wires all have a twin with a black stripe those are speaker wires. now as to the lined wire being negative or positive. i say negetive wire has the strip.My researching shows a 50/50 split of opinions from the web on that debate. i hope i was answering what you were needing
Dec 23, 2010 | Car Audio & Video
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Which colour wire is the live feed to my rear light? I am talking about the 3 wires that go directly into the bulb. They are grey, black/grey and white/back.
turn the ignition switch on with a multi meter turned ot DC 15 volts touch each wire with the red line and the black grounded to the frame or the negative side of the battery. when it shows a reading that is your feed wire. I believe it is a black wire with a white line.
Feb 04, 2010 | 2007 Suzuki GSF 1250 Bandit
Batteries show charged but no pwr
Clamp one side of [power line of your charger insert baterry pack,if amphere increase the battery pack was ok.select battery good one still run impact diver insert to the charger amphere increase good charger and battery pack. Two only the problem Battery pack or charger, if charger not function , the power transistor will be replace or buy new charger.
Dec 25, 2007 | Makita 18V LXT Lithium - Ion Cordless...
Camera wont stay on, please help
Possible that the Lens Mechanism is out of sync. If its still within warranty just bring it in and have it serviced. If not I may be able to help you out but it requires dismantling the camera,..
If any one knows a quicker and easier way maybe they can post it here But as far as experience goes thats what happened with mine,
Hope this helps
Oct 12, 2007 | Casio Exilim Card EX-S600 Digital Camera
Olympus FE-170 Digital Camera Logo
66 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
