Question about Lands Phones
Nec dt300 how can I get the phone to accept incoming calls. It doesn't ring in or give voicemail option when some calls in internally or externally
SOURCE: Two incoming calls issues
What type of phone system do you have?
Posted on Dec 22, 2007
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
  • 16 Answers
SOURCE: I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Posted on Jan 12, 2009
SOURCE: Make All phones ring when there is an incoming call
I have a DtermSeries E and the second line blinks but does not rings.
Posted on Aug 03, 2009
SOURCE: M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Posted on Oct 08, 2010
HOW DO I GET THE CF LIGHT OFF?
First, you've posted this is Nortel Phones, while your model is an NEC - you might have more luck posting in the NEC section.
When you do, it would help if you add more detail on which button (sp?) stays lit. If it's Call Forward, a second push should turn it off. If it's Message Waiting, you probably have to access voicemail.
Aug 20, 2014 | Nortel Lands Phones
How do I set up the call divert on our NEC DT300 Series phone so that all incoming calls are diverted to another land line? The info on the back of the phone is - NEC DT 300 Series DTL-24D-1A(BK) TEL...
I am not sure which country you are in, but in Australia your divert depends on your phone carrier not your model. If your carrier and call plan supports call forward you just dial their set number and follow the prompts to turn on or off.
Oct 22, 2013 | NEC Lands Phones
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
NEC DTU 16D 1A not ringing
Your PABX line settings need to be programmed for "ringing" as incoming call notification for each specific assigned number (wired port assignment).
Jun 08, 2012 | NEC DTU-16D-1 Display Telephone
NEC DT300 Series - Having a problem deleting a voicemail messages. I delete the message but the system isn't deleting the messages and the light won't go away. How do I do a hard delete?
Try accessing your voice mail from a different number. Just call your number and press pound once you hear ringing. If this doesn't work contact your phone company.
Mar 02, 2011 | Cell Phones
How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Jun 29, 2010 | NorStar M7324 Telephone
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Lands Phones Logo
324 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
