Question about Garden
Replace fuel line
How do replace fuel line please
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 31 Answers
Watch some of the U-tube videos. Type you model in and it will show you how to do a lot of different things.
Posted on Jun 17, 2014
1989 f250 460 engine fuel problem
if the fuel lines have any rubber fuel lines they could be sucking air. also try replacing the fuel caps, it may not be venting
Dec 02, 2013 | 1989 Ford F 250
How to replace fuel lines on ryobi rlt30ces line trimmer
Hope this is what your looking for.
Please rate me
Thanks,
Feb 15, 2013 | Ryobi Garden
Fuel line on MAC 3516 is broken. Where to get the new one and the fuel filter? How to replace the fuel line?
Hi szeldovich
You can pick up fuel line at any small engine shop/supply house.
One trick to insert the fuel line into the tank is to fold it the end to make it smaller than the hole in the tank...also put a little wd40 or vaseline on it to make it easy to pull/push.
Always insert more fuel line into the tank than is needed, as you have to reinsert the fuel filter back into the line and pull it into the tank again.
Here is a picture of how to route the fuel lines.
Please take time to rate me
Bud
Oct 17, 2012 | McCulloch Garden
I have a F350 diesel non- tubo with a fuel leak in back at top. replaced o ring at back injector and replaced all hose clamps but still bad runing leak. What next?
This engine has fuel lines that run to each injector from the injector pump. On the older Fords they touch each other in places. This constant vibration from the engine has caused a pin hole in one of your fuel lines to the injector. You will need to find the bad line. Can be hard as some of these are buried and hard to see. The replacement line will need to be purchased from Ford as each fuel line has to be a certain length and they are all high pressure lines. I have seen this many times in the older Fords.
Apr 05, 2012 | Cars & Trucks
Fuel line in tank dry rotted how do you replace
Hi classic11369...
Remove the old fuel line and filter from the tank...
You will insert a wire a little smaller than the diameter of the inside of the fuel line, and you will bend a small hook on the end of the line to fit over the fuel line (be sure to use a small wire) .
Lubricate the first 1 inch of fuel line with vasoline lightly...using your fingers or neednose pliers collapse the fuel line and insert it into the fuel tank, entend the fuel line long enought to go out of the fuel tank so you can reconnect the fuel filter...then pull some of the fuel line back into the fuel tank...
Please take time to rate me thumbs up
Sep 23, 2011 | Homelite ZR10926 16" Chain Saw
Replaceing fuel line in polan 3300 chain saw
Hi owjbhend...
Use a piece of wire and insert it into the fuel line, then bend a hook in the end and hook it over the end of the fuel line...lubricate the fuel line with some vaseoline very lightly...about the first one inch of the fuel line and then use your fingers to start the fuel line into the tank, once you have the fuel line in the tank give enough to hook the fuel filter to and so it can be dropped back into the tank.
Below is a drawing of how to route the fuel lines.
Sep 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Ryobi cs26 and I cannot get my replacement fuel line through the hole into the fuel tank. Is there a method to get the ruber line through?
Hi lscarmac...
There is a method to try to get the fuel line into the tank.
1...Insert a wire approximatly the same size as the fuel line opening, and then lubricate the out of the fuel line with a little oil/vasoline and then try to insert the fuel line into the tank.
Once you have the fuel line in the tank then remove the wire from inside the fuel line, don't forget to reinstall the fuel filter on the end that is inside the fuel tank.
Aug 23, 2011 | Garden
Need to replace fuel lines....does the prime bulb connected to return fuel line or the supply fuel line
Hi stglass900...
Normally the big line will be the line the fuel filter is connected to inside of the tank, and is connected to the primer bulb.
The smaller of the two lines is the return line to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Aug 16, 2011 | Craftsman 25cc Gas Line Trimmer
I need instructions on replacing the line on our Remington Lawn Trimmer
Hi pwdw71...
You will need to go to the lawnmower/weedeater parts house with a sample of both lines to be able to replace the lines with the right size fuel lines.
Also check/clean/replace the fuel filter inside of the tank.
Also take your Mfg. and model number with you.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru and primed the carburetor by the primer bulb.
You will insert the big line into the fuel tank far enough to be able to install the fuel filter.
Free Answer...Please take time to rate me
Jul 04, 2011 | Electric Garden
There is a leak around the 2 tubes from the fuel bottle when the machine is being filled or held with the fuel bottle in an upright position. Remedy please
Hi donhodgson1...
Those two fuel hoses need to be replaced with new fuel lines.
When fuel lines get old, the tend to get hard and will be subject to leaking fuel.
Be sure to mark which fuel line went where...
Jun 20, 2011 | Homelite Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
