Question about Miele CVA4070 Coffee Maker
Want to clean the grinder part of my built in miele coffee maker.
How do I clean the grinder part of my built in Miele coffee maker?
  • 1,511 Answers
Very Carefully with the power plug pulled out of the wall.
If you do not have the manual, go on line and have customer service send you a detailed instruction manual or have a technician take you through the process.
Posted on Mar 25, 2014
SOURCE: Miele Coffee maker cva 615
Actually, I had done all that and am very good about rinsing machine daily.  Finally, had Miele come out and our problem was the beans.  We had been using Starbucks beans for 4 years and there is just too much oil on the beans even with the cleaning.  The screens were fine, but there was something that I honestly can't remember that was clogged.  The technician had to take apart the brew unit to get it cleaned.  There was so much "gunk" that had built up over the years even with the descaling and rinsing.  We now use Dunkin Donuts coffee and it is amazing how there is no oil on those beans.  Anyway, thanks for the help.
Posted on Oct 20, 2008
SpotBert
  • 231 Answers
SOURCE: miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Posted on Jan 03, 2009
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
  • 12 Answers
SOURCE: Hi - I have a miele cva5060 coffee machine. The
Sounds like grinder, over heated or got jammed by foriegn item (stone, pebble, etc...). If it over heated, then wait a few minutes, and then try again. Grinder also has a heat fuse that may have burnt out. If grinder doesn't work, after waiting 15 minutes, then a technician may have to replace grinder.
Posted on Nov 17, 2010
gwshaw71
  • 83 Answers
SOURCE: is there another place tp
what model is it i have a cva 615 im parting out
Posted on Dec 04, 2010
Our Miele coffee machine is not grinding the coffee and only delivering water. I have cleaned the brew unit but still no coffee. Any suggestions?
Sounds as if the grinder and or the coffee chute is plugged with grounds, this can happen when using a very fine grind and /or a very oily bean. Sometimes the grinder can be cleared when taken all apart and cleaned with a tooth brush - but this would require a service tech for the most part - have to take quite a bit apart to do this
Oct 30, 2017 | Miele Coffee Makers & Espresso Machines
I have Miele coffee system CVA 4062 the grinder is not working properly? I have cleaned everything, Descaled all that good stuff.
Its likely to be the brushes in the Grinder motor. These are replaceable but Miele does not sell them as a spare part. You may be able top fabricate your own if your technically minded and experienced and can disassemble the machine. Otherwise grinder needs to be replaced. Regards
Jan 18, 2017 | Miele Coffee Makers & Espresso Machines
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
The grinder is not working
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
May 13, 2014 | Miele CVA4070 Coffee Maker
The grinder is not working. Only water is coming out.
Basically coffee is not being ground. Likely causes are grinder is faulty or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele. Note: A possible cause for Grinder not working is that the carbon brushes are worn away preventing electrical contact. Unfortunately Miele does not sell brushes as a spare part.
While cleaning Miele built in coffee maker, Fault 17 appeared. What does this mean?
Insufficient water intake. Check that the water tank is installed correctly. Check hoses and connections. Check water tank valve.
Feb 27, 2011 | Miele CVA2660 Stainless Steel Coffee Maker
Hi - I have a miele cva5060 coffee machine. The grinder has stopped working, any ideas or solutions?
Nov 06, 2010 | Miele Coffee System
Miele grind cycle not working on miele coffee maching
hi,
if you move the grinder level across to the left in one action it can jam up the grinder and even damage the grinder. if adjusted is required you should move it one mark, make a coffee and then move it another mark and make a coffee.
if you can't hear the grinder operating when you make a coffee then it sounds like it could be damaged.
Dec 10, 2009 | Miele CVA615 Espresso Machine
Miele built-in coffee machine. I've set the wrong language. How do I reset it back to English? Please help.
Language setting is on page 19 of the owners manual =>
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback Thank you.
Nov 04, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
358 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
