Question about Briggs & Stratton Garden
Smoking off & on badly , now can hear a tap-nock ? in motor .
Aprox. 3 yrs. old purchased at sears. model 917. 287242
  • 1,162 Answers
Did you ever change the oil? If is still under warranty I would call Sears. It could be a factory mistake. If you are talking about a riding mower it could need a valve adjustment. This is a common problem on Briggs. Need more info to tell you for sure
Posted on Mar 27, 2014
Motor cycle popping and smoking on start up
The old gas needs to be drained. Also the intank filter probably needs to be cleaned as well. The carb will need to be cleaned too.
Aug 26, 2012 | Motorcycles
My 2003 duramax is nocking blowing black smoke
WELL BLACK SMOKE AND KNOCKING CAN BE CAUSE BY RESTRICTED AIR FILTER FAULTY .INJECTION PUMP IT HAS INTERNAL FAILURE OR INJECTION PUMP TIMING OFF.USE A MECHANIC STETHOSCOPE SAME THING DOCTOR USE BUT IT HAS A LONG PROBE PICKS SOUNDS YOU CAN HEAR ENGINE NOISES.FAULTY VALVES AND FAULTY FUEL INJECTORS.YOU CAN GO TO SEARS BUY ONE.PLACE IT NEAR YOUR DIESEL INJECTION PUMP WHILE ENGINE RUNNING IF PUMP FAULTY YOU CAN HEAR IT USING A STETHOSCOPE.
Oct 22, 2010 | 2003 Chevrolet Silverado 2500HD
Won't start
fuel goes off in plastic containers,ie 3 months.try fresh fuel.metal jerry cans good for storing petrol.
May 26, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Fisher & Paykel c250T Frdge/Freezer and it has stopped freezing and cooling
Best off to call a reputable service company such as Sears. Sounds like you need a start device for the compressor. Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Fisher and Paykel Fisher&Paykel E522BLSS
WASHER WILL NOT AGITATE OR SPIN WILL FILL AND DRAIN KENMORE 800 TOP LOADER APROX 13 YRS OLD
sounds like your motor coupler bad if its making a ratchety kind of noise
Jan 15, 2010 | Kenmore 23822 Top Load Washer
Bakers pride electric deck ovens aprox 10 yrs old
It depends on the ampere rating, you will not normally be able to get a single phase supply in the UK at more than 100 amps total.
If the total oven rating is not more than 60 amps you may be ok.
Conversion would involve altering the wiring in the oven which may be costly and not worthwhile on a 10 year old oven.
Jan 06, 2010 | Bakers Pride CO11-G2 Gas Double Oven
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
Nov 15, 2009 | Ariens Garden
Whirlpool DWJR - ELE, Model LER7646EQ2, about 12 yrs old.
belt may be broke since you hear the motor running.
Sep 22, 2009 | Dryers
7 year old dishwasher motor needs replacement
No one is going to do anything for you at 7 yrs old- maybe 13 months, but not 7 yrs.
Nov 27, 2008 | Dishwashers
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
