Easytronic faults i have an easytronic 1.6 astra and it keeps stalling when i try to pull off i thought it might be the clutch actuator but unsure any advice would be greatly appreciated
2 Suggested Answers
  • 72 Answers
SOURCE: Engine Stalls when put in Gear, Suzuki GSX-R 1000 K3 (2003)
If there is a broken wire then the signal from the bypassed side stand switch could still not be getting to ecu to allow the engine to run. To test, bypass neutral switch so neutral light always on (earth it). if this lets it run then get a wiring diagram and find where sidestand switch wiring feeds ecu and try bridge it closer to eliminate wiring problem.
Posted on Apr 07, 2013
2.0 l 4 cyl. MT. Why does engine stall after it warms up?
IAC - idle air control valve ? Maybe a vacuum leak .
Nov 25, 2015 | 1995 Ford Contour
My 1993 honda accord goes into gear but when i pull the clutch out and give it gas it wont move
you pulled the transaxle and replace the clutch disc, pressure plate and throwout bearing< really?
the first thing, for all hydr. clutch actuators is to test it with 2 persons.
you depress clutch
and person two ganders at the clutch lever into bell housing. of trans-axle. then sees if it moves 3/.4 to 1 inch. if not , the MC or slave
clutch actuator is bad. replace it.
is the clutch MC reseviour. low? or empty
Mar 02, 2014 | 1993 Honda Accord
1800 vtx stalls after clutch released
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike stalls when letting out clutch
Bike only starts in neutral and Dies when put in gear
Honda VTX1800R Owner Manual service manual not owners
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1800C Owner Manual
Jan 20, 2014 | 2006 Honda VTX 1800R Spec 3
Having trouble shiftng transmission into first at traffic stop. Had to pull out in second and stalled a couple of times.
cable clutch , too much free play on leaver, adjust so 2mm gap when pulling clutch free play ! hydralic clutch , may need bleeding or free play between actuator needs adjusting , or there could be a problem with the clutch it self !
Nov 30, 2013 | 2005 Honda VTX 1800
Clutch actuater probs on 2005 mitshubishi colt easytronic
a colt jeep, do send photos, we love frankencars.
Aug 12, 2013 | 1995 Jeep Wrangler
2002 Kawasaki ZX-6R is stalling when the clutch is disengaged
Hi, Jesse the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Bike stalls when clutch is disengaged
zx6r 05 when put in gear engine stalls
Kawasaki 2000 Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Nov 03, 2017 | 2002 kawasaki ZX-6R
2006 Honda CRF 250 R stalls when you pull the clutch lever in
Bike stalls shifting into 1st gear with the clutch in
https://crfsonly.com/forum/viewtopic.php?t=36978
Honda 2004 CRF250R Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CRF250R Owner Manual
Mar 10, 2012 | 2006 Honda CRF 250 R
When coming to a stop the motor shuts down. to take off again you have to put it in neutral to restart. it then takes 2 or more tries to keep it going once you shift to drive.
SOUND LIKE FAULTY TRANSMISSION TORQUE CONVERTER CLUTCH SOLENOID.WHAT HAPPENING WHEN YOU COME TO A STOP.WHEN YOUR FOOT PRESS THE BRAKE PEDAL THE TRANSMISSION TORQUE CLUTCH SOLENOID SUPPOSE TO UNLOCK TORQUE CONVERTER TO KEEP FROM STALLING THE ENGINE IF NOT THATS WHAT CAUSING THE ENGINE TO STALL OUT.SO HAVE THE BRAKE LIGHT SWITCH CHECK OUT AND HAVE THE TRANSMISSION SCANNED FOR A TRANSMISSION TORQUE CONVERTER CLUTCH SOLENOID FAULT.
Jan 20, 2011 | 1992 Chevrolet Lumina APV
Problem installing umax astra 3400 on xp professional
Make sure you have the drivers for xp. If your unsure you can google them and be able to pull them up. try that and that should take care of the issue.Thank you for using Fixya.com
John C
Feb 16, 2009 | Umax Astra 3400 Flatbed Scanner
I was wandering if I need to replace my clutch.
Have you tried adjusting your clutch cable? If the clutch was bad you would rev the engine in gear but the bike would not speed up as it should because the clutch was slipping. But if your cable is out of adjustment pulling the lever may not be disengaging the clutch. You should find the adjustment at the clutch lever, should be a larger locknut and a smaller adjusting screw. You want about 1/2" of freeplay in the lever before it starts disengaging the clutch.
Did it stall with a big **** like you didn't pull in the lever or did it just die? If it died, maybe the sidestand switch is faulting, killing the engine because it thinks your kickstand is still down.
Jan 08, 2009 | 2005 Honda CBR 600 F
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
