Question about HP Pavilion DV5000t 1.6GHz Core DUO Centrino 1GB 80GB DVD+RW DL 802.11g 15.4" WXGA Brightview (No Op... (EZ398UA) PC Notebook
My hp pavilion dv5000ca lost the hard drive so i bought a new HD and installed winXP a couple months ago (feb) now my new HD blew and now i find myself going thru all the steps i used 1st time. i used floppy to create partitions,but now it stalls after the initial F8 format, any help?
  • 788 Answers
Sorry to here about your HP, HD problems.
1st. what kind of hard drive are you installing ? What size and kind did you have orig. ?
I would download disk manager from the internet, or if its a SeaGate drive, SeaTools and run partition manager.
2nd. Also if you have a utility in your BIOS setup to check your hard drive (S.M.A.R.T.), I would attempt to run that utility and check the outcome.
3rd. If your unit has a floppy disk drive, it is probelly a older unit and you may want to see if HP has a BIOS upgrade for it.
Also, if you check the forms @ HP, you may find others with the same type of problems.
If your unit came with a restoration disk set, I would load from that set and make any changes after-wards.
Hope this helps, try it !!
John Ray
http//www.johnrraycomputer.com
john@johnrraycomputer.com
Posted on Jun 16, 2009
Drive formatted for a pavilion for use in a HP 6005? can it work?
Hi NavyGirl1,
Your PC should have 4 SATA slots whereby you can attach your old HD to the new PC and copy the files across to your new hard drive.
Let me know if you need any further help
Best wishes,
Graemevm
Jan 23, 2012 | Computers & Internet
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
The hard drive crashed so I bought another (larger) HD for my Acer Aspire 3680. when I try to install OS Win 7, the laptop does not recognize the hard drive, new or old. The install program keeps asking...
The best option is to install WinXP on the new drive, partition the drive
C:, D:, E: etc
and use C for WinXP
Once you are done with WinXP install Win7 in D
let me know
Nov 29, 2010 | Acer Aspire 3680 Laptop
Can I replace orig hp ze1115 20GB hd w/60GB hd?
No the bios should be able to read the drive fine. The problem could be with the computer's motherboard. You should check to see if the original drive and new drive is detected in another system. Or you can try accessing them via an external casing / adapter.
May 25, 2010 | HP Pavilion ze1115 Notebook
I bought a HP M8430F and would like to install a 2nd hard drive
By set up differently you mean and ATA or SATA difference? That shoudll not matter as long as  the windows are alread on the first harddrive of the HP  Since your drive that you want to move is the second drive and does not contain the operating syastem you should be able to just phisically move the drive from one machine to the other. The new computer will see and install the drive as "FOund ne hardware" and asign it a letter. It will not disturb the data.
Jan 24, 2009 | HP Pavilion Media Center TV M8430f Desktop...
HARD DISC
If you bought it new then back up any files and take it back to the shop. If it's a second hand unit then you need to immediately back up to disc or pen anything you want to save. You are being warned that there is an issue with your hard drive. If this fails then you will lose all your information and computer won't fire up until you fit a new hard drive and install an operating system (if you actually have one). Once you have safeguarded your files it might be worth checking if your laptop is running too hot, which can damage a hard drive, is the fan switching on. There are programs free to download that can test the temperature.
Aug 27, 2008 | HP Pavilion DV6500T Notebook
My pc can't see the lacie hard drive
remove and return it again to the usb port? or maybe your enclosure has a problem?
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Aspire 5630-6288 not connecting to internet
You can go back to Vista. Should be loaded on the D section of the hard drive.
On startup press F10 and go through recoery and allow it to relaod Vista to its default configuration.
Feb 15, 2008 | Acer Aspire 5630 Notebook
Seagate SATA 160 GB (ST3160827AS) fried!
Are the logic board model numbers the same? How about year and batch manufature? check on that.
Sep 20, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
HP Pavilion DV5000t 1.6GHz Core DUO Centrino 1GB 80GB DVD+RW DL 802.11g 15.4" WXGA Brightview (No Op... (EZ398UA) PC Notebook Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
